TP Power vs horracing sss motor
This is a test that will test the TP 5850 motor against the Hor racing SSS 5694
Tp power made contact with me to do a motor test and not just any motor but the 5850 1150 kv vs the hor SSS5694 1200kv motor
Specs look like this
SSS 5694 1200kv 6 pole brushless motor
[SSS56941200] US $99.00
Click to enlarge
SSS 5694 6 pole 1200kv motor.
Type: 5694
KV: 1200
Y/D: 2.5D
Max Amp (A): 292
Max Volt (V): 41
Max Power (W): 12000
Max RPM: 50K
Non Load Current (A): 3.5
Shaft Diameter (mm): 8
Motor size diameter x length (mm): 56*94
Gross weight (g): 900
TP5850 spec
T 6D
KV 1150
Max Amps (A) 279
Max Volt (V) 43
Max Power (W)12000
Max RPM 50,000
No-load Current 4
Shaft Diameter (mm) 8
Diameter * Length (mm) 5892
Weight (g) 962
Click to enlarge
Type: 5694
KV: 1200
Y/D: 2.5D
Max Amp (A): 292
Max Volt (V): 41
Max RPM: 50K
TP5850 spec
T 6D
KV 1150
Max Amps (A) 279
Max Volt (V) 43
Max Power (W)12000
Max RPM 50,000
No-load Current 4
Weight (g) 962
As you can see on paper they look alike. The deal with TP power is to put both though the same test until there toast! This should be a fun test.
I will be using a boat and 2 different custom 1/5 buggies to do this test. Anything you want to see please let me know.
Not sure how your going to do a fair test but the sss motor is not a HOR racing motor they are just a retailer the motors are made by TFL hobbies.The test if done properly might mean something if both motors were the same size and kv but theyre not .
Mart
[TABLE]
[TR]
[TD]
[/TD]
[TD="width: 12%"]
[/TD]
[TD="width: 12%"]
[/TD]
[TD="width: 12%"]
[/TD]
[TD="width: 12%"]
[/TD]
[TD="width: 12%"]
[/TD]
[TD="width: 12%"]
[/TD]
[TD="width: 13%"]
[/TD]
[/TR]
[TR]
[TD="width: 12%"][/TD]
[TD="width: 12%"]
[/TD]
[TD="width: 12%"]
[/TD]
[TD="width: 12%"]
[/TD]
[TD="width: 12%"]
[/TD]
[TD="width: 13%"][/TD]
[/TR]
[TR]
[TD="width: 12%"]
[/TD]
[TD="width: 12%"]
[/TD]
[TD="width: 12%"]
[/TD]
[TD="width: 12%"]
[/TD]
[/TR]
[TR]
[TD="width: 12%"]
[/TD]
[TD="width: 12%"]
[/TD]
[TD="width: 12%"]
[/TD]
[TD="width: 12%"]
[/TD]
[/TR]
[TR]
[TD="width: 12%"]
[/TD]
[TD="width: 12%"]
[/TD]
[TD="width: 12%"]
[/TD]
[TD="width: 12%"]
[/TD]
[TD="width: 12%"]
[/TD]
[TD="width: 12%"]
[/TD]
[/TR]
[TR]
[TD="width: 12%"]
[/TD]
[TD="width: 12%"]
[/TD]
[TD="width: 12%"]
[/TD]
[TD="width: 12%"]
[/TD]
[/TR]
[TR]
[TD="width: 12%"]
[/TD]
[TD="width: 12%"]
[/TD]
[TD="width: 12%"]
[/TD]
[TD="width: 12%"]
[/TD]
[/TR]
[/TABLE]
Mart
[TABLE]
[TR]
[TD]
[/TD]
[TD="width: 12%"]
[/TD]
[TD="width: 12%"]
[/TD]
[TD="width: 12%"]
[/TD]
[TD="width: 12%"]
[/TD]
[TD="width: 12%"]
[/TD]
[TD="width: 12%"]
[/TD]
[TD="width: 13%"]
[/TD]
[/TR]
[TR]
[TD="width: 12%"]
[/TD]
[TD="width: 12%"]
[/TD]
[TD="width: 12%"]
[/TD]
[TD="width: 12%"]
[/TD]
[/TR]
[TR]
[TD="width: 12%"]
[/TD]
[TD="width: 12%"]
[/TD]
[TD="width: 12%"]
[/TD]
[TD="width: 12%"]
[/TD]
[/TR]
[TR]
[TD="width: 12%"]
[/TD]
[TD="width: 12%"]
[/TD]
[TD="width: 12%"]
[/TD]
[TD="width: 12%"]
[/TD]
[/TR]
[TR]
[TD="width: 12%"]
[/TD]
[TD="width: 12%"]
[/TD]
[TD="width: 12%"]
[/TD]
[TD="width: 12%"]
[/TD]
[TD="width: 12%"]
[/TD]
[TD="width: 12%"]
[/TD]
[/TR]
[TR]
[TD="width: 12%"]
[/TD]
[TD="width: 12%"]
[/TD]
[TD="width: 12%"]
[/TD]
[TD="width: 12%"]
[/TD]
[/TR]
[TR]
[TD="width: 12%"]
[/TD]
[TD="width: 12%"]
[/TD]
[TD="width: 12%"]
[/TD]
[TD="width: 12%"]
[/TD]
[/TR]
[/TABLE]
this test is a consumer test so Horracing is how he branded these sss line of motors. SSS is how I bought them and is how most are sold so I think I will stay with what I have started the post with.
ON, CANADA
That is a good motor. I run it in a 40" Promise Hobby Kevlar/carbon mono. Runs well with just a 452 prop but, can take more prop. Ran out of time testing this year and it's too cold now. I might get out this weekend to test one last time to try some larger props. I use a SF240 Pro esc.
The motors are going to be very close to TP Power but, that is to be seen.
Twisted starts a thread in a boat forum and then says he will be doing the test with buggies??? WTH is going on? I don't like to bash anyone but, it would be really nice to see him finish one of his boats run it and show it on video. He had one short video of his twin Zonda that lasted a few seconds because it flipped at the doc and he ended the vid with an expletive remark I can't repeat.
ON, CANADA
That's fine. You may notice that these motors can turn even larger props. 450 x 3 is a good start, watch run times & temps. You may be able to turn a X455 2 blade or more depending on the hull size etc...
what is the best motor for the a TFL Zonda to go 85+ MPH TP 4060 1720KV 3Y, TP 4050 1700KV 7D, leopard 4092 1730KV 3D, SSS 4092 1650KV D with a 442 prop or 4519 prop?
