1/8 Scale Cooling issues
I am having cooling issues with two 1/8 scale hydros. Running Bill Brandts set up with twin water pickup rudder. Does not appear to be getting enough water through the motor or esc. I have changed props to smaller but still running hot.
Any suggestions?
Any suggestions?
Using the SSS 4092 850 KV with mount and cooling jacket combo with ZTW 8S 150A ESC Running 2215 19 38 prop by Mark Sholund
Have Speedmaster twin water pickup rudder. It just looks like not getting enough water flow through motor!!! Are people drilling out fittings and replacing with larger ones?
Don't want to run again till I make some kind of change. Thanks for any ideas
Three things that I'm aware of, other than too much prop, that can overheat an electric drive, are:
- too small of wires between the ESC and motor
- connectors that have "high" resistance
- excessive drag in the driveline installation
Should be good, from what I can see. Are the connectors gold plated or plain? Gold plated are much better conductors than the plain ones, but are also much more spendy
