Go Back  RCU Forums > RC Boats > Speed - Electric
 Trim Tabs >
Trim Tabs
Speed - Electric For all your electric boating needs.
Trim Tabs
Old 06-28-2005 | 04:49 PM
Default Trim Tabs
What's the benefit of installing trim tabs?????
Would I benefit from installing them on a AquaJet running a 700bb and 16 cells???
Old 06-28-2005 | 04:55 PM
Default RE: Trim Tabs
Hi unclVinnie, my first question is does your boat cativate - bounce or skip across the water? If it does installing trim tabs might be a good idea. Trim tabs can be used to lower the nose of the boat down toward the water. And to help stop the bouncing, etc. But trim tabs do add drag so there is a plus and a minus to them. Another way is to move you center or gravity foward a bit. Mostly by moving your battery foward, a little bit or until the bouncing stops. I don't see a reason to install them on your boat because it doesn't bounce etc. Hope it helps. Matt
Old 06-28-2005 | 05:47 PM
Thanks WaveBlaster,
That's what I wanted to know, I thought they would improve the top speed.
If that's all they do, I won't be needing them, boat runs great, doesn't skip or bouce off the water
might do it once in a blue moon, but nothin to worry about.
Old 06-28-2005 | 10:14 PM
I don't think they increase speed... I have them on my boat because it bounces and skips really bad.[:@]Oh well. Matt
