Go Back  RCU Forums > RC Boats > Speed - Electric
 Which Epoxy? >
Which Epoxy?
Speed - Electric For all your electric boating needs.
Which Epoxy?
Old 07-07-2005 | 12:45 PM
Default Which Epoxy?
Which Epoxy should I use. I picked up some "Quick Set Epoxy Gel" - sets in 4 minutes and some "Quick Set Epoxy" - sets in 5 minutes. I am using these for patching a hole in my boat... which one should I use? Thanks in advance. Matt
Old 07-07-2005 | 03:02 PM
Default RE: Which Epoxy?
Use the regular epoxy, not the gel.
If you find you don't have much time to work with it, you might want to pick up some 30 min epoxy. If you ever use any fiberglass cloth, definately at least use 30 min, if not 60-90min.
Old 07-07-2005 | 04:08 PM
Thanks, I'll return the other one. Matt
