Go Back  RCU Forums > RC Boats > Speed - Electric
 Gecko or flea question >
Speed - Electric For all your electric boating needs.
Old 10-23-2005 | 04:05 PM
Default Gecko or flea question
I have a reef racer and I wanted to get a new hull. I was wondering if I could use the electronics and motor from the reef racer to any of this two hulls? I will buy better electronics in the future but could I used it this for now? Also which hull would u guys recomend and prop?
Old 10-24-2005 | 09:33 AM
Default RE: Gecko or flea question
My suggestion is that you leave your Reef R. the way it is. If you are going to go with a new hull, then start with good new electronics - not that the electronics in the RR are bad, they just aren't up to par with what could go in the other micro size hulls. You be a lot better off that way.
