Go Back  RCU Forums > RC Boats > Speed - Electric
 New Aqua Jet - Greasing Shaft >
Speed - Electric For all your electric boating needs.
Old 01-23-2006 | 08:21 PM
Default New Aqua Jet - Greasing Shaft
Hello,
Well my first ever RC boat - an Aqua Jet Extreme - arrived today. I was a little concerned when I saw the box it arrived it because it was dented and scuff pretty badly but it appear the boat is fine despite UPS' best efforts to the contrary.
I am going over the "Important Tings to Remember" Sheet that came with the Aqua Jet and one of the things it mentions it to "Oil the shaft before running." Knowing that I would need to grease the shaft, I went ahead and just purchased the initial grease from Offshoreelectrics.com. While greasing the shaft is probably something extremely simple to do once you do it the first time, I was a little hesitant to start unscrewing things based on the instructions that came with the Aqua Jet.
So, would any fellow Aqua Jet Extreme owners mind giving me a brief run down of the correct method for greasing reomoving, greasing, and replacing the shaft?
I appreciate any guideance.
Chris
P.S. - If there are any "before you run" or other "tips" you can pass along, I be interested in hearing them also. I believe I've successfully charged the batteries so hopefully I'll be able to take it for a run tomorrow.
Old 01-23-2006 | 11:28 PM
Wide Open's Avatar
Default RE: New Aqua Jet - Greasing Shaft
i dont have any tips specific to the aqua jet, but i do recamend you go to auto zone and pick up a big can of bearing grease for about 3 bucks. it works great and you get a ton of it that will last forever. that is after your grease from offshore electrics runs out.
Old 01-23-2006 | 11:51 PM
Thanks, I'll consider that. Someone else mentioned using marine grease which is something I have from greasing our big boats trailer. I would assume that would work also?
Old 01-24-2006 | 08:06 AM
Wide Open's Avatar
yeah, that would work just as good as any sort of high speed high temp grease.
Old 01-24-2006 | 08:27 AM
Last night I held off on attempting to remove the shaft but I definitely would like to water test the Aqua Jet this evening so I'm going to pull the shaft tonight to grease it. From looking at the pictures in the manual I guess I just loosen the rudder some and loosen the screw that holds the shaft to the prop and pull the shaft out (I guess it just easily slides out)?
Old 01-24-2006 | 09:41 AM
Nitronutt's Avatar
Yup, easily slides out - nothing to it. I believe that steven suggests greasing the stock shaft, but the flex shaft that comes with the Extreme version eliminates that.
Steven can you verify??
Old 01-24-2006 | 09:58 AM
wallstrookie's Avatar
lol lawtyger, welcome to the aqua jet xtreme owners club.
your making this way more complex then it should be.
i just remove the rudder and unscrew the nut where the shaft meets the flexshaft. grease then put it back. about a 2min job
oh yea and when you put it back make sure the prop doesnt hit the rudder, i think you should have a nickel's thickness worth of space between the prop and rudder.
make a video... and let us know how it goes...
Old 01-24-2006 | 02:55 PM
Your making this way more complex then it should be.
Ain't that the truth Sorry about that. But thank you everyone for your patience.
