Go Back  RCU Forums > RC Boats > Speed - Electric
 can not seperate hull >
Speed - Electric For all your electric boating needs.
Old 11-13-2006 | 04:28 PM
Wannago100+'s Avatar
Default can not seperate hull
Hi,
I am having a problem seperating the hull of a hydrosport electric boat, the 10 or so screws seem to be aluminum and are standard phillips head but are just stripping out when I try to unscrew. I am leary of trying to drill. any sugestions?
Old 11-13-2006 | 04:31 PM
CadillacDTS2001's Avatar
Default RE: can not seperate hull
throw it out . . those boat suck so much . . there might be glue around it that you are missing
or there might be sccews under the decals you are missing
Old 11-13-2006 | 10:17 PM
Quicksilver's Avatar
well, if you really want to try, and youll need a dremel for this, use a cutting wheel to cut the heads off the screws, or throw it against a tree, that would do it, but maybe not the way you wanted. I wouldnt drill them, that would go badly, if you could get a hack saw blade through the seam(which would serve a double purpose of checking for glue), you could cut through the screws.
