medium cats
medium cats
It might be awhile before I move to one, but I've been checking out cat hulls. I like the Aeromarine Mean machine 29". Funrcboats.com has one RTR w/a brushed Cordite. I was also thinking of strating with a hull and just putting one together on brushless, but this RTR boat will run between 40 and 50 according to the specs. Does anybody have one of these? Anybody have any thoughts?
RE: medium cats
chances are its the BL version of the cordite . . even with that motor you wont see 50mph . but with the ss1 then you will se about 35mph or so
link me to where you see this ?
RE: medium cats
Thought I had included a link in the original....must have had a brain fart instead.
http://www.funrcboats.com/ProductInf...id=AERMEANRTRE
RE: medium cats
I assumed it was an SS1 since it doesn't specify "brushless" and FDM doesn't list anything other than a 775 Cordite like the one I have. I seem to remember reading somewhere about a nemsis brushless motor w/a Cordite label on it. But that was a pretty old post somwhere if I remeber right. Just curious. How did you determine this one was indeed brushless? If that's the case, then I am even more interested in the rtr.
RE: medium cats
umm well i have 2 BL cordites . they are quite good.
but i dont know of a any cordite SS1 that will do 50mph in that hull. i may be rong . but it could be brushed
RE: medium cats
Here's the response...
The old Coredite motor is no longer available. We are able to build this
boat with a Graupner 700 series brushed set up (Jeti Navy ESC) right now.
We are working on a brushless version of this RTR and it will use a Hacker
motor and ESC, but the project is still in the works. Expect the brushless
set up to be approx. $250 more than the current price. I hope to launch
this brushless set up in January.
I hope this answers your questions. Let me know if I can assist you
further.
Kristen
FunRCBoats
further.
Kristen
FunRCBoats
RE: medium cats
on 18 cells . . thats a little hot of a set up. don't like the sounds of that
and how do you like you mini scat cat ? was going to buy one . but it was abs and i don't like abs
FL
RE: medium cats
im going to get a ruder with duel water pickup's and run one of the lines to the esc to help. The prop wash is just cool enough to keep if from shutting down.and the micro scat cat is a blast. it run's the high 20's to low 30's I don't like the abs but for the price you cant beat it.
RE: medium cats
regardless of water cooling . you get that motor over 170 degrees and you can kiss the power good bye
what are you gearing for that trans and what prop ?
yes 29.95 for the hull . i would probably fiberglass over it
RE: medium cats
Exactly what I was thinking. To go a bit further, I was thinking credit the $150.00 or so for the brushed setup and THEN add the $250.00 for the brushless. Net increase...$100.00. I'd be all in at the point.
RE: medium cats
Wow! With that, I could assume that w/a brushless setup (which ever one that ends up being) and a straight driveline that it wouldn't top 40mph.
RE: medium cats
ORIGINAL: jallen355
i could but a esc and BL motor separate and make it less then 400 . . . BUT it wouldn't be good
RE: medium cats
I guess I need to consider builing it myself. Now I have to consider using a transmission. I hate when I talk myself out of something I like.....[:@]
