Go Back  RCU Forums > RC Boats > Speed - Electric
 Out board help needed >
Speed - Electric For all your electric boating needs.
Old 11-29-2006 | 03:11 PM
Default Out board help needed
Just wondered if anyone has successfully managed to mount a 700 motor onto a Graupner GTX 650 outboard unit
Cheers Gordy
Old 11-29-2006 | 04:30 PM
CadillacDTS2001's Avatar
Default RE: Out board help needed
probably be really easy . i think the mounting holes are the same so it is just a drop in
Old 11-29-2006 | 07:34 PM
ryan_t888's Avatar
I thought the 500-600 series motors are 24mm bolt spacing and the 700 series are 1 1/8" bolt spacing? The 700 is also larger in the diameter, not sure if it would fit in the case?
Ryan
Old 11-29-2006 | 07:41 PM
This is true.
You would have to do a mounting plate mod for the 700 to fit. Also you possibly wont be able to use the stock cowle
