CEN WAVE SHARK
NY
CEN WAVE SHARK
ok i didnt get anywhere on the last thread. i want to upgrade it to a BL. can you tell me which one and what electionics do i need, be specific. link
MI
RE: CEN WAVE SHARK
You could buy the supervee brushless on towerhobbies.
[link=https://www.unitedhobbies.com/UNITEDHOBBIES/store/comersus_viewItem.asp?idProduct=4187]motor[/link] or this motor with a 5mm shaft [link=https://www.unitedhobbies.com/UNITEDHOBBIES/store/comersus_viewItem.asp?idProduct=2077]5mm shaft motor[/link]
[link=https://www.unitedhobbies.com/UNITEDHOBBIES/store/comersus_viewItem.asp?idProduct=4316]esc[/link]
hope this helps,
mike
hope this helps,
mike
My Feedback: (81)
VA
RE: CEN WAVE SHARK
I would go with a Feigao Instead of the SV motor. and the Phoenix 80 or 125 would be a good esc.
you can get them at www.offshoreelectrics.com or
http://www.starluckrc.com/catalog/
NY
RE: CEN WAVE SHARK
thnx for the info. what size motor can fit in the wave shark. will the whole supervee 27 bl system fit on the wave shark? the rtr 32mph wave shark, if i put the sv27 system, do you think it would go faster then the 32mph?thnx
My Feedback: (81)
VA
RE: CEN WAVE SHARK
I think 32mph is about the limit of the hull before it gets too unstable.
When I first got my SV my motor burned up in the second run. If mine burns out again I will be replacing it with a Feigao.
If you are running it in waves, you won't be going all that fast anyway.
