Go Back  RCU Forums > RC Boats > Speed - Electric
 15mins Epoxy >
15mins Epoxy
Speed - Electric For all your electric boating needs.
15mins Epoxy
Old 03-31-2007 | 04:58 PM
Default 15mins Epoxy
Hi, im using 15mins epoxy to seal outside the hull, how long i have to wait after that to do sanding job by sand paper, anyone know??
Old 03-31-2007 | 05:10 PM
Default RE: 15mins Epoxy
Read the back of the bottle. Personally I multiply that amount x2.
ORIGINAL: kevinle
Old 03-31-2007 | 05:26 PM
Quicksilver1's Avatar
Assuming it doesnt say on the bottle, I would wait a MINIMUM of 24hrs
Old 03-31-2007 | 06:24 PM
I agree with the 24 hour recommendation. The longer you allow it to dry the stronger the bond. The surface will feel oily after it dries. Make sure to wipe it down with acetone before sanding to avoid build up on the sandpaper and scaring of the sanded surface. Do it again after you sand it, or glue anything to it, and before you apply paint so that the paint will stick to a clean surface.
