high voltage speed controls????
guys does anyone know where i can find a speed control which i can use on two motors and can handle real high voltages, i also want to use more than one high amp battery pack..
thanks in advance
I WANNA GO FAAAAAAAAAAAAAAAAAAAAST
thanks in advance
I bought 20 100AMP forward 80AMP reverse servos from RCSmart in HongKong. Use three of them in a PT boat application with three speed 600 BB motors and three 12v10000Amh batteries (DCell). ESCs have worked reliably and with very little heating. ESCs cost $20 each if you bought 10. I have been happy with the purchase. I can go fast but at low cost. NmH Batteries, however, cost about $119 each. Boat weighs in at about 28lbs due to battery weight but still goes very fast
The CC Phoenix HV-110 Brushless Controller
Volts NO BEC 50 MAX
NiCad or NiMh Cells NO BEC 36 MAX
Lipo Cells NO BEC 12S MAX
It's an air craft esc...but water cooling can be adapted.
Volts NO BEC 50 MAX
My Feedback: (81)
VA
He didn't say wether it was for brushed or brushless. Since he said two motors I assumed he was talking about brushed motors.
Nitro Ahmed, clear this up for us. Are you talking about brushed or brushless motors? If you are talking about brushless, then you are going to need two esc's.
