1/8 H&M T-plus Hydro twin Lehner 2250, can be done?
Hi, i just got a 1/8 H&M T-Plus hydro hull, im thinking about twin drive with 2250 motor, anyone do twin drive for a hydroplane b4? please give me some advise.
RE: 1/8 H&M T-plus Hydro twin Lehner 2250, can be done?
no, not 2 motor in one gear box, i mean 2 separated motor and 2 separarted outdrive system and 2 props, just like dual engine in some out rigger out there,
Hi did you get a good answer? Which Lehner you use? I ve built in a 2250/12 in my old shovelnouse with 32 cells runs very fine. let me knew. George [email protected]
A single motor setup will be better for many reasons. One, it will cost a lot less, you will not need two ESCs and two motors, two props and drivelines, two struts and two rudders. It will run much better and be a lot easier to set up with a single large motor and single prop too. Don't try to re-invent the wheel, build one the way other experienced baters have first. Then on your second big hydro you can try some exotic setups.
