Go Back  RCU Forums > RC Boats > Speed - Electric
 Building  rigger... >
Building rigger...
Speed - Electric For all your electric boating needs.
Building rigger...
Old 06-23-2007 | 08:15 PM
My Name Is Brad's Avatar
Default RE: Building rigger...
I just got bought some balsa for the sponsons. I will hopefully make and finish them tommorow. I will for surely post pictures sometime tommorrow night.
mIke, have you started yours yet?
you better start soon. Your going to need all the time you can get to build a rigger that beats mine.[X(]
Old 06-23-2007 | 09:09 PM
ya probably. what size motor are you using? i have a esc for a 480 size motor
Old 06-23-2007 | 09:26 PM
I am using that graupner 480BB motor. I have all of my other electronics from my old boat. I might try to make a custom rudder but I'm not sure. I still need to buy the motor, battery, laquer and epoxy for the hull, and a flexcable and other misc. hardware. Are you for sure making one or not? IS your BBY boat running yet?
Old 06-23-2007 | 09:30 PM
no hardware isnt in stock yet. this should tie me over till i get it. i have the money any way.
Old 06-24-2007 | 11:16 AM
im using a 400 7.2v graupner motor and 1000mah lipo. the dimensions will be 17x10. i know its big but i will upgrade to a 480 eventually if the speed is poor. im hoping to hit 20 which it should but well see
Old 06-24-2007 | 04:36 PM
  #31
I got the sponsons of my rigger done. I went with a really simple design that was recommended from another site. Tommorow I need to finish all of the trimming on the hull. I will get pictures tommoroow b/c my brother is gone and I'm not sure where his camera is. I still need to mount the sponsons. I will do that late tonight when I get home from fishing. When you see pictures tommorow the hull should be slmost completely done beside epoxy and sealing,ect.
What are you making your hull out of? I used pine for the main hull and balsa for the sponsons and all other stuff.
Old 06-24-2007 | 05:14 PM
  #32
im mainly using balsa. i printed the plans out and im ready to build just need to buy the balsa now
Old 06-24-2007 | 07:28 PM
  #33
Will dylan make one? he should so we can all race. where are you going to drive it?
Old 06-24-2007 | 07:59 PM
  #34
I dont think he would make one. but Im not sure. I just got back from fishing from him and I was talking to him about it.
I am finishing my boat tonight and tommorrow morning. I am using wood glue to glue everything together b/c it is very strong, but I need to make sure I seal it well b/c it will come off in water. I got a bunch of tips from a few sites about building riggers. One site suggested that you mount the sponson rods on top of the sponsons. I did this. It explained why but it was really complicated. But I did it anyway b/c they said it was the best way to attach them. I also switched the sponsons that I made to more "simpler" ones. I got the idea off a 6 cell brushless SAW rigger. They are very easy to build and they are supposed to provide a lot of lift.
btw, I will drive it at the pond by my house and the fairhaven pond.
Old 06-24-2007 | 08:11 PM
  #35
sweet. make sure you post some picsa of it whenever you get them. sounds like youve done a lot of research on it. good luck!! i hope mine turns out as good as yours. so you are using the 480 bb race. im just using the 480 race 7.2v. you will have more power than i will. my esc cant handle the draw of the bb cause it is rated 15a and the bb pull 16a and probably more on water. o well, i hope it is goin good for you.
Old 06-24-2007 | 08:32 PM
  #36
your boat will probably weigh less than mine, though, b/c mine is made out of a lot of pine. If you make yours completely out of balsa, it should be about equal b/c of the weight difference. what plans are you following?
Old 06-24-2007 | 09:12 PM
  #37
predator scaled down to 2/3 size
Old 06-24-2007 | 09:16 PM
  #38
what hardware r u using. custom or what?
Old 06-24-2007 | 09:22 PM
  #39
I am going to have to buy some nice, adjustable hardware. For riggers this is a must b/c the prop angle and rudder setup is the most important factor to how it runs. I will NEED adjustable hardware to make it run right. I am going to be doing a lot of setup on the rear end before it runs good. I have heard of people who spend hours setting up their riggers prop angle. (prop angle is the most important factor)
Old 06-24-2007 | 09:31 PM
  #40
yup. u got it. the hardware that im using im goin to modify to make adjustable. the strut angle is adjustable just not the hieght.
Old 06-24-2007 | 09:40 PM
  #41
r u usin fullers or sumthin?
Old 06-24-2007 | 09:51 PM
  #42
I'm not sure what hardware I'm using yet. Ill figure that out when the time comes that I need it.
They have good Midwest balsa at sidetrax hobbies. I got 3 sheets of balsa (4 inches wide by 24 inches long rectangular pieces) for 8 bucks. I think they also have some at hobby lobby.
Old 06-24-2007 | 10:11 PM
  #43
ya they have it there too. im ordering mine because on balsa usa they have bigger pieces there
Old 06-25-2007 | 09:43 PM
  #44
I got pictures I just havnt had time to upload them yet. Tommorow for sure they will be up.
Old 06-25-2007 | 09:59 PM
  #45
and balsa is cheaper. only 9.00 to do the whole boat. but shipping might get pricy tho. its light but takes up space so i guess i will find out soon.
Old 06-26-2007 | 08:57 AM
  #46
did you order the balsa yet?
Old 06-26-2007 | 09:19 AM
  #47
no im making a boat for a guy at the marina where we put our real boat in. hes giving me 200 to make the boat and i can keep what ever is left over. ill order it soon.
Old 06-26-2007 | 01:07 PM
  #48
Banned
what would be better in a 21 inch rigger a 7S brushless motor or a 9L ??
Old 06-26-2007 | 02:00 PM
  #49
Banned
im look to run 6-8 nimh 3700 cells
Old 06-26-2007 | 02:25 PM
  #50
idk for sure because im just getting in to building and seting up riggers. but i would use the 9l if you use 7-8 cells. a 7s would be an extremely hot setup on 8-cells and hot on 7.
