pro fisherman
pro fisherman
trying to program a futaba radio to work with this boat.does anybody know a good place to start..i cant seem to get it going and i know im just missing a stupid step here..
WI
RE: pro fisherman
try using just a reciever pack and servo to see if your esc is bad. on a lot of newer esc's the plug can go in two ways so make sure thats right
OK
RE: pro fisherman
I'm not sure about what you are trying to do exactly. If you're swapping out Futaba for the original electronics that came with the boat, then that's one thing. If you're trying to 'mix' Futaba with some of the original electronics, then that's something else altogether and it may not be compatible (different controls on different 'sticks' sort of thingy). {And the way this day has gone, I may be misunderstanding the whole thing!}
- 'Doc
- 'Doc
RE: pro fisherman
your a jerk diegoboy..just kick me when im down
still cant get to arm..i will not get it wet until the stock glitching piece of crap gets out of there..it was glitching right in front of me..
VA
RE: pro fisherman
Nice vid.
I'm not knocking the pro fisherman... just Dirty's
LOL
Dirty, Maybe you can get it going by getting in the water with it...
LOL
LOL
LOL
ON, CANADA
RE: pro fisherman
I changed the stock radio for a Futaba FM radio in my Profisherman. I was never able to get the stock ESC to communicate with the new radio no matter what I did or adjusted. The solution was to replace the stock ESC. I got a Proboat model and it armed right away without any problems. I know others that had the same problem and ended up replacing the ESC as well.
The glitching your experiencing with the stock radio will improve significantly with the FM radio but won't be eliminated completely. The glitching is a problem with the bass boat itself - I think the antenna wire is to close to the motor and picking up interference from it.
