The Unofficial all things Jet drive thread
#2526
RE: The Unofficial all things Jet drive thread
ORIGINAL: lipdaddy
take off the nozzle and put a piece of tape on one side (same with the hole in the boat) and fill it in with two part epoxy. when it's cured remove the tape.
yep thats how i would it to.
#2527
ON, CANADA
Ah key word is nicely/decorative. I could do it that way but when ya look at it, it would still have a hole through it(u should see jet villain, clear holes all over, severly needs paint)even though it was sealed.
Hmmmm... just thinking... could simply add led light to hull, and fill in the jet for now, I think I'm going to order short steering eventually. Here's pic, sure hope it's available in black, white looks wrong![:@]
#2528
MT
Use JB weld instead of clear epoxy it will be darker in color or just take black permanent marker and color the epoxy. For the top hole epoxy it and then put a small decal or sticker over the top like a dole banna one. Or take a piece of tubing w/bend in it to make it look like an exhaust pipe. Just some thoughts want more?
#2529
ORIGINAL: headhunter23
#2530
ON, CANADA
Dragon might do that! Sent email asking about other colors and shipping.
Damfurst good ideas. The sticker idea is pretty good if I don't make it a rear light. If I do light, then will add green and red at front.[:-] Never done it seems.
Ivan.
Ivan.
#2535
Well good news for me my esc has arrived in HK, they have tested it found it faulty and will issue replacement.
That was Monday so hopefully should get it in a week or so.
Water cooling is sorted just waiting for esc to test/abuse the boat, have tub tested with cheap low amp esc and all seems well.
#2538
ON, CANADA
Good to hear!
Sent email to kehrer about the short steering nozzle. Unfortunately it does only come in white. Not sure whut to do... paint it? or send to dragon!
#2540
ON, CANADA
Hmmm... dunno. Could permanent marker it but I'm sure over time it would change color. Crappy. Looked at how much to just send the mini nozzle, almost 34 bucks for just that. Ouch![:@] Bad conversion to euro.
Ivan.
Ivan.
#2542
ON, CANADA
Ahhh we'll see... at that price I'm just going to hope the epoxy works on current one. I really like the shorter jet though, I think it will do better at not getting hit as I'm trying to avoid putting in a nozzle protector. Will probably be kicking my self when i break it on a rock this summer.[:-]
#2543
great news guys. got my motor and esc and did a test in the tub . with both 2 blade stock and 3 blade mod . on both 3s and 4s . all and all its a great set up the motor barly got warm with out water cooling !!! the 3 blade did great on 3s lots of thrust . more the running the stock 2 blade on 4s . cant wait to get her in the water. just need to tap for the cooling and to make a radio tray . and glue the deck back on .
#2544
Sounds good dragonfire which 3 blade prop did you use?
My replacement esc was shipped from HK today their time so not too long for me to wait now i hope.
Here's some news pics, no esc for obvious reasons
#2545
i used the last one on that page the 42mm http://www.offshoreelectrics.com/products.php?cat=57
#2546
Dragon, look at these props [link]http://www.loyalhannadockyard.com/PROPS.htm[/link]. Particularly the Rivabo #P543-031 4 blade about halfway down the page. Looks like a good candidate for cutting down for impeller use. Not bad prices either. Sundog
#2547
man that a great find . good work . just looking at some they look like sub props . that 7 blade is screming turn me down .
vinny she look great . ill post some pics of mine later today . i need to pick up some fuel tubing to run the water cooling
#2548
I liked the look of the seven blader too, might have to spend the evening hunting for possible multiblade impellers.
Thanks dragonfire seems like a lot of work has gone into it without much visible difference, shame my construction pics where all low quality.
#2549
heres the pics ... be kind. im not done this is befor i clean it up, run the cooling and fill a hull on the side thats for the exshust for the nitro motor
#2550
Looks good wishing i'd put the water pickup where you did but couldn't find a threaded connector like the one you have.
Have to have a race
Have to have a race
