Go Back  RCU Forums > RC Boats > Speed - Electric
Reload this Page >
The Unofficial all things Jet drive thread
Speed - Electric For all your electric boating needs.
Old 10-08-2014, 04:17 AM
  #4976
89MIB
haha yer ill be the Ginni pig for that motor. i never new you could get jetski hulls that's a grate idea. What length are they?
Old 10-08-2014, 08:24 AM
  #4977
Jay-Em
You mean the Wavechopper? Or the kehrer jet boat? Wavechopper is 48cm, the kehrer jet sprint II hull is about 66cm.
Old 12-01-2014, 12:25 PM
  #4978
Chs51
Can you provide a photo of the "twin servo mount" for operation of the reversing buckets?
Old 12-14-2014, 12:01 PM
  #4979
Haje74
Hi guys,
Im a modelbuilding nut with a soft spot for jet-drives like most here, and I have been working on a file for making simple calculations on RC jetdrives in order to determine the power one needs to achieve a certain rpm and therefor jetspeed. With this file you can get an insight in what kind of setup (batteries/e-motor) is most likely to give the result you want from your model jet-drive.
It is easy to use; just fill in the required numbers, and it will show the required power to reach a certain RPM.
Remember this file is a first setup; there are numerous more variables to consider, but it is a handy tool that will give a good estimate as to which setup is most likely to work, and which wont.
You can download the file here:
http://www.powerboat-friends-freisin...English%29.xls
I have tried to assemble some of the calculations that people on the Snikwah forum used to design their own jetdrives.Try it and see what you think; any comments on improvements are welcome.
Cheers,
HJ
Old 01-01-2015, 06:38 PM
  #4980
bqspeed1
Hi Folks,
I'm totally new to jet drives for boats. Was looking at getting the standard NQD 757-6024 drive with 390 motor from ebay. Anyone know how much thrust this provides?
From what I've seen so far, replacing the stock 390 motor with a brushless motor greatly improves performance, is this true?
One last question - if I briefly connect a 2200 mAh lipo battery to this setup (no speed controller, just for a quick test), would it burn out the motor by overheating, or would it be ok to run 10-20 seconds?
Thanks!
Old 01-01-2015, 06:50 PM
  #4981
SicRC
Hi speed, a brushless setup makes a massive difference. They're total junk out of the box, a lot of them don't work at all, but they're fantastic fun after modding them. I make lots of parts for modding the Tear Into jet unit and can put a kit together with everything you need to mod the boat including the motor, ESC and all other hardware.
A 2S LiPo won't hurt your stock motor and 3S is ok for short bursts if you just want to see what it's like.
Also, I've set up a new forum which is dedicated to Modding the Tear Into where you can post pics of your build and get all the help and advice you might need.
http://sicrc.freeforums.org/nqd-tear...ods-t3-10.html
Old 01-01-2015, 07:24 PM
  #4982
bqspeed1
Thanks for the quick reply SicRC! What would you recommend in terms of brushless motors for getting the most out of the NQD jet unit with a 2S or 3S battery unit? Will the motor's shaft fit or is an adapter necessary? Any other parts needed besides the ESC? How much would all this run?
Thanks!
Old 01-01-2015, 07:53 PM
  #4983
SicRC
Below is a link to the motor I recommend. On 2S it's pretty quick and on 3S it's crazy Have a look around my eBay store for other stuff I do, the ESC I recommend for that motor is the 35amp one, they're both water cooled.
I recommend modifying the jet unit too. I run a flex shaft and a 3 blade impeller that I make. There's also a modified stator housing and nozzle (the bits that attach to the back of the boat). My modified stator housing has 2 nipples on it, one provides pressurised water for the cooling system and the other one provides a vacuum, you attach a piece of silicone tube to that and run it through the transom to the bottom of the boat and it sucks out any water that gets in while you're running.
For $129, I do a complete kit with Motor, ESC, servo and mount, all the mods for the jet unit, battery tray, and everything else including screws and cooling system tubing.
I don't do complete kits through eBay though, they take too much commission I'll PM you my email address and we can sort it out, I can send you a PayPal invoice for payment.
Old 01-01-2015, 07:59 PM
  #4984
SicRC
I just sent a PM, not sure if it worked though, my email is [email protected]
Old 01-03-2015, 02:46 PM
  #4985
bqspeed1
Hey Steve,
Thanks for the offer, but I'm not sure I'm ready to make a purchase. Still doing some research. How important is the water cooling if I plan to run in short bursts? Why is a flex shaft needed, is that to accomodate the modified impeller?
Brian
Old 01-03-2015, 03:05 PM
  #4986
SicRC
No problem Brian,
Depends on what you mean by short bursts, and a lot of other factors like motor size and kv rating, and whether you're running 2S or 3S. Also whether you're running fast on open water on just messing about at low speed in creeks and rapids.
The cheapest way to go is to use an outrunner which is air cooled, and an oversized ESC, if it's only delivering half it's max amps then you should get away without water cooling.
Old 01-06-2015, 04:54 PM
  #4987
bqspeed1
Thanks Steve,
Can the 2.3 mm coupler for the NQD unit be manually drilled to 3.17 mm (I assume a 1/8 inch drillbit would be close enough) or does this have to be done using a drill press?
Does anyone waterproof their motors for jet boats (in particular for salt water)?
Would a decent size motor like this one destroy the 16 mm NQD jet unit, or would it be able to handle that power with say a 2S lipo?
http://www.hobbyking.com/hobbyking/s...ner_Motor.html
Brian
Old 01-06-2015, 08:54 PM
  #4988
SicRC
Ideally you'd use a lathe to drill the coupler out, but even then it may not run true, but you've got nothing to lose by trying.
That motor will be fine Brian, and no need to waterproof it, just give your motor a squirt with a water dispersant spray before and after running. Inox is the best spray I know of as it doesn't leave a residue build up the way WD40 does. Another brilliant product is CorrosionX.
Old 01-08-2015, 04:50 PM
  #4989
bqspeed1
Hi Steve,
Another thought I had was getting two NQD units and using this smaller motor that shouldn't require a modification to the shaft coupler:
http://www.hobbyking.com/hobbyking/s...erCooled_.html
Do you think a single 2S lipo would be enough for two of these if I just want to do ~10 second full out bursts and don't care about running for long durations? I am leary of using a 3S lipo because these are 4800 kv motors so they should be turning over 50,000 rpm on a 3S which is way too high for an NQD unit, right?
Do I even need an ESC if I am just doing short, full out bursts?
Do you think this 2 motor idea is more powerful or is it better to choose a single bigger motor on one NQD unit. It looks like this is the best watercooled choice they have instock:
Does the shaft collar on the NQD unit actually block water from going into the motor, or is it relying on the motor being above the waterline?
Thanks!
Brian
Old 01-08-2015, 10:42 PM
  #4990
SicRC
Whether you can run 2 jet units depends on the hull. it would need to be quite a bit bigger than the NQD Tear Into and have quite a shallow V, otherwise the jets will suck air as soon as you start to plane. Can you put up a pic of the transom and some measurements?
If you want to use a brushless motor then you have to use an ESC.
Those little motors would be a good choice for a twin setup if the hull is suitable. ON 2S those motors are great, but on 3S you'll cook the front bearings.
The rubber shaft seal does keep most of the water out, but keeping the shaft greased is a good idea too.
Old 03-02-2015, 02:53 AM
  #4991
QIK-RX4
Default My jet boat collection.
Thought I might share our collection of jet boats. As per most it started with the mini jet boat, then I spent some time hunting down one of the ABC Hobby jetski's (have a second one nib) and last the kmb jet sprint boat.
Old 04-07-2015, 09:31 AM
  #4992
Haje74
Hi guys I posted a new project in the electric forum (it's a jetdrive project so just wanted to let you know);
http://www.rcuniverse.com/forum/spee...-jetdrive.html
Let me know what you think; my guess is I could go for bigger batteries
Cheers HJ
Old 05-10-2015, 05:31 AM
  #4993
wildwillhappy
hi all
just found this site, come over from rc groups. Cannot find any nqd jet boats in uk but did look at a site to import them from china but then what would I do with a whole load of them, we all know that the rc gear is not very good and the speed controller and batter are pants so would have lots of hulls and jet drives left over.
wild
Old 07-02-2015, 07:35 PM
  #4994
Quicksilver
Quicksilver's Avatar
Hey you guysss!!! I'm back and planning on the jet villian v.10 to be RTR by tomorrow! It will be brushless, 12 cell and weigh roughly a 1/3 of v.7.
pics to follow soon
Old 07-03-2015, 02:29 AM
  #4995
Quicksilver
okay, it's done, so the hull is modded a lot more now, I moved the drive back 3 inches and added the step in the transom. The the entire electronics outfit is replaced, with the entire setup my truck, the Traxxas E-Revo VXL. I'm very excited to get this in the water.
some old and new photos.
Name:	VILLIANCOMPARE - Copy.jpg
ID:	2107106   Click image for larger version
Name:	VILLIANV10C - Copy.jpg
Old 07-14-2015, 11:11 AM
  #4996
Quicksilver
So some of you might have guessed, this didnt work out. I blew a cell in the batteries. I was running 12 cell. The motor and esc were running cool but the batteries cannot handle the amperage. Back to the drawing board. In the mean time, I'm putting that running gear in a 10" RIB lmao, it'll be a monster, will have a much smaller prop.
Old 10-09-2015, 07:43 PM
  #4997
damfurst
http://youtu.be/IVoJMZdntcA New jet boat from Youngsters jet boats 23" Brinksman Feral. Maiden voyage on the pond.
Old 10-22-2015, 09:36 AM
  #4998
damfurst
http://youtu.be/adQtE1jR5N4 Here's new video by Youngster himself of the Brinksman Feral.
Old 11-07-2016, 05:52 PM
  #4999
mickieb49
Sale going on the Mickiebeez jets , price will not be repeated:
http://www.ebay.com.au/itm/Mickiebee...-/112179066310?
Old 01-23-2017, 04:31 AM
  #5000
89MIB
Its Been about 2 and a half years since I posted up. I had this on the back burner for a while but its almost done. Its had it test run and about to get some paint. its extremely fast off the line.
ID:	2197836   Click image for larger version
ID:	2197837   Click image for larger version
ID:	2197838   Click image for larger version
