Go Back  RCU Forums > RC Boats > Speed - Electric
 SV27 Radio Issues Interference >
Speed - Electric For all your electric boating needs.
Old 10-31-2007 | 07:30 PM
Default SV27 Radio Issues Interference
I got a few runs out of the boat and switch the antenna over to a Dean's 2-piece. After the install I got around 3 runs and now I have interference when the motor is running. It started one day at the pond after the first set of packs were done, on the second set I got loads of interference. If I start the motor with the RX inside the box it happens, if I pull the RX out it seems to go away. The antenna wire is not in contact with the motor wires or batt. leads. Anyone know what to do? I lose complete control[X(]
Old 11-01-2007 | 06:54 AM
GRANT ED's Avatar
Default RE: SV27 Radio Issues Interference
First step is to check if anything is loose. Metal to metal contact will cause RF interferance.
Old 11-01-2007 | 03:29 PM
Everything seems tight, the RX did not get wet. What next
Old 11-01-2007 | 06:09 PM
many of us ,have had rotten performance from the stock AM radio. I had multiple runaways,before I swaped out and went FM. No more glitching or runaways. I used the receiver and transmitter from a losi mini LST,that i got off ebay for $35. hope this helps.
Old 11-02-2007 | 08:15 AM
That does help, because I though the stock one was 72 or 75mhz. I think a new radio is in order, maybe a Traxxas because they are very cheap and I have had good luck with them.
Old 11-02-2007 | 05:23 PM
Well got it to work today, I had to face the RX away from the ESC and insulate the antenna with E-tape. Seems to work now but hearing about runaways scare the crap outta me. Can you tell us more about the runaways?
Old 11-02-2007 | 06:09 PM
Wheelnut's Avatar
My Feedback: (81)
I can tell you that if you had of performed some searches on RCU for SV27, you would have found these threads and almost all of them talk about the problems with the stock SV27 radio.
http://www.rcuniverse.com/forum/m_54...tm.htm#5480011
http://www.rcuniverse.com/forum/m_51...tm.htm#5193877
http://www.rcuniverse.com/forum/m_63...tm.htm#6319908
Here are some more threads that may answer some more of your questions
http://www.rcuniverse.com/forum/m_48...tm.htm#4835624
http://www.rcuniverse.com/forum/m_48...tm.htm#4835667
http://www.rcuniverse.com/forum/m_48...tm.htm#4843027
Happy reading and welcome to RCU
Old 11-02-2007 | 07:13 PM
Wheelnut I know you are a valued person on RCU and your knowledge is not replaceable... but come on... 351 different posts on props and water cooling??? Don't fall victim to the "do a search" statement, please! These types of replies plaque the forums already.
PS None of the topics answer this question
Old 11-02-2007 | 07:44 PM
Wheelnut's Avatar
My Feedback: (81)
OK. sorry.
and you did a good mod that I have not heard of yet.
But seriously, get rid of the stock radio. The cost of a decent radio will pay for itself by avoiding a serious crash and ruining your SV. Even a cheap FM radio is better than the stock AM radio.
Old 11-02-2007 | 08:49 PM
I should just ditch the thing already[:'(]
