Go Back  RCU Forums > RC Boats > Speed - Electric
 motor recommendation >
Speed - Electric For all your electric boating needs.
Old 11-26-2007 | 05:12 PM
Default motor recommendation
hi,
i have a small boat 15X40cm which was originally a toy rc boat.
the electronics don't work anymore,so i'm thinking to convert it to a real rc boat.
i already have everything i need from other projects, the only thing is,i don't know what motor to choose.
here are some motors i have:
a 370 size motor,with 5:1 gearbox,
and a 180 size heli motor,
both brushed
batteries will be 900mah 3S
what would be a good overall motor for it?
it don't has to be a speed monster.
Old 11-26-2007 | 05:32 PM
Default RE: motor recommendation
Use the 370 and get rid of the gear box, you have a pic of the hull? For boats this size you can go 3000-3500rpm brushless with about 20 amps and that should put you close to the hulls limit. Or at least generally, especially running on 3s lipo.
Old 11-27-2007 | 11:37 AM
thanks for your reply,
here is a pic from the boat ,
it is not the actual one but very similar.
btw,
everything is made of plastic.
Old 11-27-2007 | 04:40 PM
if you want a bit more performance, get the graupner 480bb Race.
reasonably priced...great performance!
It depends what speed control you're using - the motors you have are brushed, correct?
going brushless may be a little more expensive, but I'd only go brushless if you want "speed monster".
