Speed - Electric For all your electric boating needs.
SAW SV
Old 01-30-2008 | 01:29 PM
Default SAW SV
Someone on another forum was asking what would be the fastest feigao motor he could run in his SV for streight away dragging? He's running a Hydra 120 and IB4600's. What do you guys think? I know this boat isn't meant for streight line racing but I just thought I'de get him some more opinions to help out.
Old 01-30-2008 | 01:34 PM
CadillacDTS2001's Avatar
Default RE: SAW SV
if you really want a 540 size motor go to hacker. order a 5XL, get the hi temp magnets and throw on some boca berings
run the boat for about 20 seconds and see how it goes.
the boat if ran SAW is a P mono which i believe is up around 70 mph.
you SV 27 hull would be stupid at anything over 50.
get a diffrent hull
Old 01-30-2008 | 02:47 PM
Default RE: SAW SV
I think he's planning on running it at the 'fastest SV' event.
Old 01-30-2008 | 02:49 PM
Default RE: SAW SV
Oh yeah i remeber that.
I'd go with a 1515 1D ( 2200 KV)
Old 01-30-2008 | 02:59 PM
BB Modss's Avatar
Default RE: SAW SV
1y is 2200kv, 1d is 4100kv IIRC
Old 01-30-2008 | 03:30 PM
Default RE: SAW SV
oh okay.
i knew it was a 1 in there
Old 01-30-2008 | 03:47 PM
BB Modss's Avatar
Default RE: SAW SV
Iv never had a 1D but im going to re wire mine so i can have winding options like on the 30xx series
Old 02-05-2008 | 03:04 AM
Default RE: SAW SV
The guy just whants to make his sv as fast as possible and doesn't whant to have to be limited to 1 or 2 passes. He just whants to be able to run allmost to fast for the sv and run the whole battery packs down w/o overheating his packs or esc. He doesn't whant to spend more than a feigao or maybe ammo costs. I don't think he's actually going to be racing it. I told him if he really whanted to run saw he'd only be getting a couple minuites before heat becomes an issue and he doesn't whant to have to come in and cool off after every couple passes, so I think he really just whants to make it a very fast sport boat. What motor would be pushing the envalope in that price range and would be safe with the 120 amp esc he's allready got?
Old 02-05-2008 | 04:00 AM
BB Modss's Avatar
Default RE: SAW SV
540 9L motor on 4s lipo and a 120amp esc, x640~642 will put the boat faster then it can handle. You asked for SAW..so we gave it to you I have a SV that can run 60 on a good day, what it takes to get there is far more then you should ever want to do. better hulls out there for running saw.
