Getting Llumar Hydro brushless.
NB, CANADA
Hi guys,
I just purchased a Proboat Llumar 1/12 hydro boat without the nitro engine and pipe. I was wondering what brushless motor from Feigao would be the perfect choice. Also, I have a Castle creation Hydra 120 esc that I will remove from my Losi LST2 brushless system from Fine Design. The hull center section does not have a lot of room but I think I would be OK for a 3S lipo at the nose. At the nose is the only place I can put it.
Any set up ideas would be appreciated including props needed.
Thank you in advance.
Dave
Dave
why do you have a boat speedo in a car?
man that must really rip up your drive train with no break. . . forward and to reverse
NB, CANADA
Hi,
The way it is set up, is by using a seperate receiver battery pack and using the supplied brakes and servo. Look at www.finedesignrc.com. and see Losi truck.
I was running my llumar boat on a Nemesis 8XL motor with a Hacker Navy 70 speed controller. I ran up to 4s. I actually have the motor, speed controller, and two 3s lipo packs if you are interested. I will sell all for $150.00. You can call me at 858-822-9097. The lipos are Thunder Power extreme packs 2200 milliamps, and used them in Parellel.
