HA3618 in a HYDRO
TX
I recently purchased a Hi-Max HA3618 rated at 4500kv. I wanted to put it in a Blu-By-U ABS 28" cat. Did I goof and get a too high of KV rating for this boat, or no? I was going to use a Baracuda 80 with two 4200mah six packs wired for 14.4 volts. Any imput would be great.
Tks,
Mike
Wichita Falls TX
Tks,
Mike
Wichita Falls TX
True.
Have you tried to calculate the RPMs? As I got to know 50 000rpm is more than ok..
4500kv * 14.4 = 64800rpm! in water it will be about 20% less but still quite alot.
so there is a question what prop will "fit", will engine and his bearrings will do and will esc handle the currents?
