lipo worth it???
FL
lipo worth it???
I have a lightly modded sv27. I don't race it. I run IB4200 batteries. Is it worth it to switch to lipo? Is there that big of a difference for recreational use? Just seeing if it is worth it before I spend the cash. What do you all think or your experience?
ON, CANADA
RE: lipo worth it???
LiPo is definitely worth it for a sport boater or racer.
Advantages:
- Cheaper in Long run
- Life of around 3 yrs
- Hold voltage better over life span
- Better discharge current
- Higher Load Voltage
- Longer run time
- Less heat produced
- Lighter
- Bigger smile on your face!
Be sure to follow the LiPo rules. Charge appropriately and always store at 3.4v per cell. Never discharge more than specified. Applies to all LiPo cells.
Ryan
Advantages:
- Longer run time
- Lighter
Ryan
Most top LIPO assemblers use Enerland cells from Korea, but not all Enerland cells are alike in performance and durability. Enerland tests the performance of its cells and charges more for the best ones. The lower performing cells go to those pack builders who sell to the mass market and to discount houses. And because they don't use the top rated cells, they definitely will not perform as well as the premium packs. For mild to moderate sport use, the cheap packs may be a good choice, but for high performance use, this isn't the place to skimp. Try to pull 20c amps from a cheap pack, and you may find it permanantly damaged, even though the specification sheet says it is good for that discharge rate.
According to Radio Control Boat Modeler magazine, the premium packs are ThunderPower, FlightPower, PolyQuest (owned by Enerland).
For the Super vee I would buy two 2s packs...either the 25c or the more expensive 30c.
Two of these: http://www3.towerhobbies.com/cgi-bin...?&I=LXRWA8&P=7
Super Vee's low voltage cuttoff is TOO LOW @5.4 volt for Lipo use. So bring boat in early to prevent cell damage. The Super Vee's 5.4 volt LVC works perfect for NIMH.
ON, CANADA
The SV ESC cut's out at 2.8v per cell when fully charged LiPo's are used. If you are going to rely on the SV ESC for a LVC, only use fully charged packs as the ESC takes a percentage of the voltage during initial battery connection.
2.8v per cell is very similar to where my castle ESC's cut out even though they specify 3.0v per cell. Found this out with a Data Logger.
For Maximum LiPo life bring in the boat before the packs come close to dumping.
Ryan
Ryan
Check out www.airthunder.com I just got 2x5000mah 7.2v lipos hope to try them soon. My friend flies them and loves em.
Save $20.00! on at least a $149 order from Towerhobbies. To claim savings 011WV.
CA
I am thinking about trying these http://www.rclipos.com/Elite.htm, Not a bad price.
They would be backed by RC Lipos.
Looks like a good choice for us budget minded folks.
The Elite lipos are very good packs and I've seen many of them around. They seem to perform very well, especially for he price. Pat at RC Lipos and Mike at Cheap Battery packs are doing them together. Two very honest and reliable vendors, you should be very satisfied with the Eltie brand.
ORIGINAL: detox
Here is what my source, who is a major Enerland distributor, had to say when I asked about this:
There are times Enerland has cells that do not meet the rated capacity. These are offered off to any distributor that wants them at a reduced price but they will not sell the loose cells and have to be constructed in to battery packs that they will label with the capacity they are. Enerland does not want bad PR so they monitor this product very closely.
Also PolyQuest and PolyRC are the same packs with different labels on them. And as far as one vendor getting the "better" Enerland cells over another, well that simply does not happen. a 3,800 mAh 25C Enerland cell will be identical regardless of which pack vendor sells them.
