SV27 RTR two Beeps instead of one?
Need help guys,
Yesterday run my SV27 second time(first time prop killed in first 50 feet) and it started to do weird things!
I don´t even touch the controller and it runs turns etc.. so i did have to stop after 1min.
Now i have checked all the connections etc. and didn´t find anything. In the radiobox was a few drops of water not much.
WHEN i armed it i get two Beeps instead of one and it won´t center the rudder anymore(runs it to other end)?
1.It put the radio on.
2. connect the batterys and get Two beeps instead of one
3.Pull the throttle to full and get Two beeps instead of one and release it and get 4 beeps.
What is going on[]
Don´t find any info what these two beebps mean?
What is going on[]
FL
RE: SV27 RTR two Beeps instead of one?
Mine beeps twice also but everything else is fine. I need to set my rudder position because it would do the same thing. now that it is set up still beeps twice but all is ok.
Well i can say for sure that it´s not normal and the turning control is now totally fu...up...!
http://www.aquacraftmodels.com/techs...qub17tech.html
Something is wrong on the receiver or something[:@]
Grim could answer to this beep beep and beep beep beep beep.....
I use 4 of these on different boats. They all beep slightly different, but they all have been working fine for 2 years. Probably the reciever.
