Chips in SV27 hull!
CA
RE: Chips in SV27 hull!
Both! I had to sand the boat down because of an ugly paint job. I got a few but nothing major as it did not leave holes. I also need to smooth out scars as well. More sanding or some sort of putty? Also what epoxy? I currently have a new kit of "Epoxy 30."
Pacer Z-Poxy finishing resin part # PT-40
http://www3.towerhobbies.com/cgi-bin...&I=LXCX58&P=ML
If you plan on repainting the boat (as I assume you will) you will need to use a color coat of primer. By this I mean to use contrasting primers to find the high spots so that when you sand it back things will be flat.
