Nitro to electric
CA
Nitro to electric
Hello every one, I am going to convert a boat from nitro to electic. Can you help me out and give me some links to some good sites for product ?
Thanks all.
Thanks all.
ON, CANADA
RE: Nitro to electric
www.offshoreelectrics.com and www.towerhobbies.com will have everything you need.
My recommendation:
A Feigao 9XL - motor OSE
Hydra 120 - ESC OSE
4s 25C 4900 Flight Power cells - Tower Hobbies
38mm prop to start
With a new power system, you must check the temperature of your new motor, ESC, and cells every 45 seconds. If everything is less than 130F you may continue running. If after a long run nothing is hot you can increase prop diameter.
Once you find the right prop for your hull on my combo, you should be around 40mph.
Ryan
My recommendation:
Hydra 120 - ESC OSE
38mm prop to start
Ryan
