Go Back  RCU Forums > RC Boats > Speed - Electric
 electric outrigger kit (must be cheap) >
Speed - Electric For all your electric boating needs.
Old 07-01-2008 | 09:50 PM
Default electric outrigger kit (must be cheap)
trying to find electric out rigger kit that is inexpesive and will possibly run on my electric car motors(from 27 turn to highly modded). ive been trying to find these kits and no avail. any help is appreciated
Old 07-01-2008 | 10:46 PM
Default RE: electric outrigger kit (must be cheap)
You could build the predator outrigger. Plans are free, dont remember where to ge em, anyone? It is an old design tho
Old 07-01-2008 | 11:36 PM
BACKEMF's Avatar
I may have them... archived...
Old 07-01-2008 | 11:42 PM
any plans would awesome, let me know if you find them. will it require a different motor with your design or will good ol car motor work?
Old 07-01-2008 | 11:45 PM
BACKEMF's Avatar
I hope this PDF loads... nope...
Here is the link: http://www.equipoolea.com/web/planos...0Outrigger.pdf
And a build thread too: http://www.rcuniverse.com/forum/m_66.../anchor/tm.htm
Old 07-02-2008 | 08:30 AM
ryan_t888's Avatar
The Predator Rigger would be your best option. It was designed for such motors.
Ryan
Old 07-02-2008 | 05:08 PM
I am almost finished my 75% scale Predator Rigger that I will be powering with an outrunner, should be fun, also the plans are free so you can't go wrong!
Old 07-03-2008 | 11:44 AM
My Feedback: (35)
will a blizard rigger work for what he needs. if so guy pm me
Old 07-03-2008 | 12:36 PM
ryan_t888's Avatar
Yes it would.
Ryan
Old 07-04-2008 | 11:56 AM
got the plans off link and blew them up(pedator). guy at copy store pulled off web site link and scaled them on the spot ,cost me like 3 bucks for 3 copys so i could butcher one for patterns , use one for layup and a spare for that just in case episode(pop spilled on table,glue stuck to it etc.) than ks to all and ill be beginning the wood cutting today before i go out on my real boat to watch fireworks tonite. ill give an update later and get more input for the hardware setup later. one last thing , where do i go to get the blue foam for the sponsons???
Old 07-04-2008 | 01:29 PM
ryan_t888's Avatar
Lowes or Home depot is where I go.
Ryan
Old 07-04-2008 | 01:56 PM
MORE SPEED's Avatar
Just ran the boat yesterday (predator) at the Marine challenge event. Only had 1 day of testing, but went to the event, did 15 laps in 5 minutes, and won the event. . I was using a stock 27 turn motor that you could get for about £5. It was slower than I wanted, the cooling didn't work, so the motor was smoking, but it did what I needed it to do, and it did the job well. Give it a go. 1 piece of advice, the solinger hardware really isn't actually that good for a rigger.
MORE SPEED
Old 07-04-2008 | 02:06 PM
ryan_t888's Avatar
5 minutes is a long time to run a rigger. Congrats!
One questions though. What is wrong with the Solinger Rigger Hardware?
Ryan
Old 07-05-2008 | 04:50 PM
im about ready to build up the boat and now i definately need advise on hardware. octura stuff i have used with success but do i want 1/8 stub with prop or 3/16. somewhere down the line i may run 8 cells and a brushless so i definatly want 3/16 drive cable. not only does octura hardware work its also the cheapest with parts available every where.
Old 07-05-2008 | 04:53 PM
ryan_t888's Avatar
You want .130 flex with a 3/16" stub shaft stepped down to 1/8"
That is in my E1 rigger.
Ryan
Old 07-05-2008 | 04:56 PM
so i want 3/16 stub and strut with 1/8 step for prop?
Old 07-05-2008 | 04:59 PM
ryan_t888's Avatar
Some thing like this.
http://www.offshoreelectrics.com/pro...od=oct-oc64pkg
Ryan
Old 07-05-2008 | 05:03 PM
so do u think the octura full rig setup available from this site is sufficient anfter bedurring ,polishing and sharpening
Old 07-05-2008 | 08:35 PM
CadillacDTS2001's Avatar
how about one of these?
http://www.offshoreelectrics.com/pro...igged-insanity
