Go Back  RCU Forums > RC Boats > Speed - Electric
 how to cut down a prop? >
Speed - Electric For all your electric boating needs.
Old 09-22-2008 | 01:53 AM
Default how to cut down a prop?
Hello
I have a 35mm plastic prop and want to cut it down to 30mm.
Is this possible?
If so how?
[img][/img]
Old 09-22-2008 | 05:18 AM
Default RE: how to cut down a prop?
is this to run all the time or just to see if a 30mm will work best because i cut down one with a file put a dot on one of the blades then run the prop over(rotationg it so its even) 5 times then the other blade,i wouldent use it all of the time but just to see what prop size i needed to get
Old 09-22-2008 | 07:27 AM
CadillacDTS2001's Avatar
plastic?
u can do it but it will turn out like crap.
get a brass one... ABC, octura, GRI novarossi. CMDI
Old 09-23-2008 | 12:36 AM
Ok ok
Whats the best website to buy these kind of props.
Dylan
Old 09-23-2008 | 03:10 PM
SV27dayton's Avatar
Can't you just use sand paper? I smooth out my CF props with paper actually sharpen them with it. One time I got a little carried away and removed too much diameter while doing this. I'd think you could do that. Would be a good experiment to see what prop to order at least.
Old 09-23-2008 | 11:58 PM
I havent actually made the boat yet. I was going to put it in a micro rigger. What size prop would be best for a 370 brushed motor in a rigger
