Unofficial "NQD" Tear into Jetboat Thread
#2901
My Feedback: (81)
VA
RE: Unofficial
Preacher, Hobbypartz is a great USA supplier. I use them all the time. They also have great batteries. I use the Gens Ace in most of my planes.
The motor you picked looks good to me, I used to run fast electric boats all the time. I usally try to over rate my esc by a good margin. I ordered a 50amp from Hobbycity.
Here is a 60 amp from hobby partz that would work fine. http://www.hobbypartz.com/seaking60aboat.html
This would help save the esc in the even that the motor may get something stuck in it and the amps sky rocet.
I am sure others will offer good advice also for you to choose from.
#2902
My Feedback: (81)
VA
RE: Unofficial
ORIGINAL: Joshsubmec
I have a major water problem in my boat..im pretty sure its coming through the ''shaft seal'' not sure how to keep it in place any help would be great thanks
#2903
RE: Unofficial
ORIGINAL: Preacher7
Sundogz the motor and cooling jacket will take 4 to 6 weeks to get here from China. I really don't want to wait that long. Do you know of anyone that has these in stock in USA? I can't find them if so. What about this motor with 3S? http://www.hobbyking.com/hobbyking/s...00kv_300w.html If so what amp ESC needed?
or this one also with 3S and what amp ESC? www.hobbypartz.com/07e-c-sl-10t-2848-blue.html
#2904
RE: Unofficial
Thanks Wheelnut, I'll keep that part in mind, but for now they are out of stock. I'm mostly stuck on an equivalent to the 4450 motor and cooling jacket or finging it here in the USA.
Sundogz, am I right that I'll use 3S batteries with the 3900KV motor? If so i'm ready to order the HobbyWing 2848 SL 3900kv motor and the SeaKing 60A ESC. I can drill out the coupling no problem. Once I'm clear on 2S or 3S I'll get batteries ordered. Is 35C or 40C adequate or should I go higher?
thanks a lot guys for the input.
UPDATE:
wouldn't you know HobbyPartz is out of the 3900 motor and the 60A ESC.
UPDATE:
#2905
RE: Unofficial
Welcome to the forum mate
I run the Hobywing 2848 3900KV on 3S, it's fast and fun I used cheap 60A ESCs first, burned out two of them, and now I'm using a good quality 120amp ESC, which I've had NO problems with
Just letting you know, if you want to, you can use the original coupler... 3.17 converts PERFECTLY to 1/8th inch, either you've got a laithe or a press drill?? Perhaps someone you know has one?? Worst case scenario, you can always drill it out by hand, but carefully, so you get it straight
You only need 5 to 10mm drilled out too
Hope that helps
Martin
ORIGINAL: sundogz
You'll need a 3.17 to 2.3mm coupling (try to find this in the States!)
Hope that helps
Martin
#2906
RE: Unofficial
hey seehuusen thanks for the info. I'm glad to hear from someone that has run this combo. Do I REALLY need 120A ESC? I got the imression a SeaKing 60A would be adequate. Is that motor going to draw that many amps?
I used to be a machinist so doing this kind of stuff is no problem. I'm just not at all familiar with brushless motors and ESC's even though I've been in electronics all of my life.
thanks
thanks
#2907
RE: Unofficial
to be honest, a good quality 60Amp should be more than enough... I just got peeved off with me burning them out, and when I looked for another one, I got the better quality one, which happened to be a 120amp one... I think these motors spike at like 40-50amps MAX so you should be OK
#2908
RE: Unofficial
Sundogz, am I right that I'll use 3S batteries with the 3900KV motor? If so i'm ready to order the HobbyWing 2848 SL 3900kv motor and the SeaKing 60A ESC. Once I'm clear on 2S or 3S I'll get batteries ordered. Is 35C or 40C adequate or should I go higher?
#2909
RE: Unofficial
I have not used this larger 3900kv motor with the NQD's smaller jet drive, but do use it (on 2S) in an ABC jet ski with it's larger drive and it is quite zippy. 40C lipos will be adequate, but you will not regret getting higher 'C' rated lipos if you can afford them. I am currently running [link=http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=11179]this 2900kv[/link] 600W outrunner with no motor cooling on 3S with a 60A esc and am very happy with speed and runtimes. I know that doesn't help you, but you can see the can of worms you've opened up by asking!
#2911
RE: Unofficial
Just ran across this. Was wondering if it is new news in this forum?
http://www.proboatmodels.com/Product...ProdID=PRB3656
#2912
RE: Unofficial
ORIGINAL: Toyotatrucks83
Area = Pi x Radius squared
Radius of 13=6.5; Pi=3.14
3.14x (6.5x6.5) 42.25=132.67sqmm
Radius of 19=9.5
3.14x (9.5x9.5)=283.4 sqmm
#2913
RE: Unofficial
Thanks for the info sundogz. I'd be willing to try a twin drive jet boat. But I think a hobby grade hull would be a better choice. Any suggestions? I really like the size of the nqd tear into. I'm currently building one. I think a slower speed twin drive jet boat in the 20" would be a cool too.
#2914
RE: Unofficial
The [link=http://www.hobbyking.com/hobbyking/store/__11984__Turnigy_Taipan_Fiberglass_V_Hull_385mm_Hu ll_Only_.html]Turnigy Taipan[/link] and the [link=http://www.hobbyking.com/hobbyking/store/__11983__Turnigy_Cobra_Fiberglass_V_Hull_385mm_Hul l_Only_.html]Turnigy Cobra[/link] both are fiberglass and have 90 degree transoms, so would be good candidates for twin 'Duck' drives or an NQD/Graupner mini drive.
#2915
My Feedback: (81)
VA
RE: Unofficial
I'm going to ask a question I should have asked a long time ago.
Is most everyone here using the stock jet drive?
I used to have a mini graupner jet drive but I don't know what I did with it. I'm going to do a search tonight. But I think I sold it a long time ago. [&:]
#2918
RE: Unofficial
ORIGINAL: sundogz
Radius of 19=9.5
Radius of 19=9.5
ORIGINAL: Wheelnut
Cool! No problems yet? How many runs?
Is anyone else experiencing long load times on RCU?
I've run my jet boat for a while now, maybe 40 battery charges through it... I've run it on the beach, in salt water/ sand and in the creeks with mud and crud... NO PROBLEMS (and I don't run a grate or anything like that either!!!)
I've got a complete spare boat, so if it ever died on me, I've got another boat
Cheers
Martin
PS. Time out errors and slow loading times seems to be the go for me too
#2920
RE: Unofficial
Hey guys can I permanently glue in the removable ramp that is attached to the original intake grate? It seem there is no reason not to but there may be a reason I havn't come up against yet. Secondly when the ramp is in place there is a gap between it and the end of the housing (which was addressed several pages back with two drawings). It can't leak but the gap seems like it could disrupt the water flow. If it is moved fully to the rear of the housing the rear edge on top would have to be trimmed a little. Any thoughts?
#2921
RE: Unofficial
Sundogz you have mentioned several times super glueing the pump assy into the hull. What if it has to be replaced. How will you remove it? I like the idea but I'm worried that I could never remove it in the future. Will the super glue remover attack the hull material? If not then that might work.
#2923
RE: Unofficial
I used silicone to glue my drive in, plenty of it, and it's 99.9999% water proof
Sicaflex might be a bit better, but longer drying times
#2924
RE: Unofficial
I have recently had problems with the email link to this forum not taking me here - I have to manually get on and locate this thread. They must be experiencing problems of some kind. On gluing the jet to the hull, if it doesn't leak (around the jet body) I don't remove it - there is no need to. But if it leaks, I'll remove the jet body and reinstall it and the intake ramp permanently, eliminating any potential leaks. I used to use superglue, but it outgasses and leaves a white discoloration, so I now use a 2 part epoxy made for plastic. I then install the stator housing to the transom with silicone. I have never 'worn out' a jet drive bore, but if it was to happen, I can re-line it in the hull easily enough with a drill bit and 1/8" brass tubing (if the hull was still in decent shape by then). And let's face it - it's just a $45 boat. If something went bad wrong, I'd just buy another boat.
Preacher, the intake ramp is installed fully to the rear - the bottom two screws of the stator housing pull it into place. What needs to be trimmed? Pics?
#2925
RE: Unofficial
i used longer screws to hold the thingymajig to the transom and they protruded into the hull, the water pressure when running forced the water to run up the thread into the inside of the boat, issue 2.3 million & 1....
