Unofficial "NQD" Tear into Jetboat Thread
#451
RE: Unofficial
Hi Every body.
I'm come from Thailand.
My Boat Picture.
Thanks: ฝากไฟล์รูป*าพ construction เว็บสำเร็จรูป
Specfication
Dragon Inrunner Motor 3000 kV (480S)
ESC Dragon 60 Amp
Towerpro Servo SG91R
Composit Props X427 Resize to 19 mm
My Boat Picture.
Specfication
ESC Dragon 60 Amp
#453
RE: Unofficial
Hi Every body.
My Boat Picture.
My Boat Picture.
#455
RE: Unofficial
Hopefully anyone would would be interested in this offer reads this before I order later.
http://hobbyking.com/hobbycity/store..._20C_Lipo_Pack
etokyopop and i are ordering some of these from hobbyking later today so i can have them by the time i get home from thanksgiving. if anyone else would be interested in ordering some also i would be willing to add yours to our order to save on shipping from them. let me know asap if you are interested (or i guess anything else from hobbyking) by either replying or emailing me - deivionstarx (at) gmail.com
#457
RE: Unofficial
Yes, I'm thinking the combo in post 412. I would be running either on calm water or my creek along the yard which does not flow terribly fast after the spring run off. Do you think with that combo, Stick with the 2450s or 2600s OR drop down a bit for wt. I like run time, but don't want it too nose heavy either
#458
RE: Unofficial
ORIGINAL: Wheelnut
Just to let you guys know, I have two of those exact batteries and they work great in my brushless planes
#461
RE: Unofficial
that is one super-slick boat.
any chance you have extra ride plates (whatever the piece on the bottom is called, i think it is a ride plate) that you would be willing to sell? those are amazing looking.
also, do you have a metal propeller/impeller? or is the sticker just there to support the company?
#462
RE: Unofficial
Yep, slickest ride plate I've seen in a while. Looks store-bought. I'm curious about the motor blocks - were you getting some flex (movement) with the stock method? And it seems a shame to have something protruding beneath the hull of a jetboat (water pickup) - just something to get hung up or broken off (like a prop!). But it looks like it will get the job done to be sure. Protect that impeller with a grate/mesh and you won't need to make many more impellers. Great pics - please post videos if you can! Sdg
#465
MD
RE: Unofficial
i know i hope nothing happened
last time he logged in was b4 i even got my tear into
anyway, i got the servo mounted in the old servo mount with velcro on the top and bottom. so so far so good
#466
RE: Unofficial
ORIGINAL: sundogz
Translate English to Thai Language some word I,m not understand.
#467
RE: Unofficial
ORIGINAL: aumsdh
ORIGINAL: sundogz
2. Why the wood motor holders?
3. An intake grid will save your impeller from damage
4. Please show us some movies of your boat
Your English is better than my Thai, which reminds me of a drink (I couldn't resist). Sdg
#468
RE: Unofficial
ORIGINAL: ryanwilson277
#471
RE: Unofficial
ORIGINAL: Wheelnut
Double sided tape is what the racers use. Been there done that.
#473
RE: Unofficial
ORIGINAL: Wheelnut
, I'll always be in the shadows, watching, protecting and advising at least until I get one myself
Oh, and learning
Oh, and learning
#474
RE: Unofficial
ORIGINAL: nomobux
Velcro might be a little sketchy for a servo ( movement ) Might be better to hard mount or hot glue.
My observations on proper servo mounting in order of good to bad:
1. Adjustable mount secured with fasteners (pop rivets, screws, bolts/nuts etc): easy to adjust/remove/reuse
2. Same mount secured with ca, hot glue, epoxy, etc. : secure, but more difficult to remove
3. Double back foam tape - tenacious, not adjustable: have to cut it off to remove, then remove adhesive with solvent
4. Hot glue - good adhering, not adjustable: can pry off if needed: need glue gun
5. Double sided tape (carpet tape) - easy to install, adheres well: can pried off but with possible damage to servo/plastic hull
6,7,8 - yada, yada
9. Velcro - does not hold well or long - allows movement of servo: Easy to install/remove
#475
RE: Unofficial
I'm going to back ryanwilson on this one. If he kept the original servo mount/clamp setup and put velcro on both the top and the bottom, I could see that holding a servo really well. It will have positive pressure from the top and bottom clamping the velcro and the servo. My guess is if the servo is big enough to fill the space well, it's not going anywhere.
Innovation happens all the time, keep your eyes open or you'll miss it.
[edit: spelling]
[edit: spelling]
