need 1/8 shaft size strut
CA
Hey guys
The metal strut on my bj26 has got a little crack in it from wear and tear.
Anyone know a good strut that has a 1/8 shaft size?
I found the miss vegas strut assembly(silver) w/brackets but it seems to be out of stock at most places.
http://www3.towerhobbies.com/cgi-bin...?&I=LXPGS3&P=7
RE: need 1/8 shaft size strut
try this site - www.r2hobbies.com
in their products under boat accessories they have a LOT of cheap hardware including struts.
CA
I can't seem to find any 1/8 struts in their section, though they have a couple unlabeled ones that look kinda small.
Any other ideas?
I'll try and post a pic of the cracked strut soon.
Any other ideas?
CA
My flex shaft size (wire part) is about .150 size and the prop shaft size is 3/16 for the strut and then 1/8 for the prop.(just realized I measured it wrong.[:@]
I guess I could get one of those octura hardware sets that'll have the right sized shaft, but I am on a bit of a budget.
http://www.offshoreelectrics.com/products.php?cat=69
go back to that site i sent you, they do a .150 cable and a 3/16 stub shaft.
I normally just buy the stub shafts from OSE and then solder my cables into them myself
