Go Back  RCU Forums > RC Boats > Speed - Electric
 convert nitro to electric >
Speed - Electric For all your electric boating needs.
Old 10-09-2008 | 02:35 PM
Default convert nitro to electric
I have a nitro vee I want to convert to electric and use as a rescue boat for my gas boat. Does anyone have any suggestions for a cheap and simple conversion.
Old 10-09-2008 | 04:03 PM
Default RE: convert nitro to electric
you can turn it in to a singel drive villain . powered by a 700 if your just useing it for rescue then just remove the nitro motor from the alum plate and mount a electric to that plate and use a flex cupler to hock it to your stock drive line
Old 10-15-2008 | 09:19 AM
I was considering removing the engine and using the return to shore motor but the shaft is tiny .09". Do they make a coupler for that size. The stock drive shaft is .15 or 4mm. What is the shaft size of the 700 motor?
