X-Power Brushless 100a ESC
This would be for a SV-27 with ammo 36-50-2300
Has any body used this ESC that I saw on OSE's web site?
[link]http://www.offshoreelectrics.com/proddetail.php?prod=xpo-blb100a[/link]
I like that it has a low voltage cut off and the internal water cooling.
Bruce
Bruce
CA
RE: X-Power Brushless 100a ESC
Hey tortuga, its a good esc for the money. they say its rated to 100 amps but from other users its more like 70, it is a good upgrade from the stock esc. i run it also like you with the ammo 2300 motor and it is a cool running esc. you need to run a receiver pack with it and get the usb programer that OSE sells it really helps if you are using lipos and nimh. I have over 10 runs with the x power and it is great. You also cant go wrong with OSE prouducts. good price, good esc and great with the ammo motors. hope i helped[&:]
I see a lot of guys running this one with good results: http://cgi.ebay.com/100A-Brushless-Motor-Speed-Controller-RC-ESC-Parts_W0QQitemZ270293977067QQcmdZViewItem?hash=ite m270293977067&_trkparms=39%3A1|66%3A2|65%3A15|240%3A1318&_trksid=p3286.c0.m14
ORIGINAL: StangLX302
See this thread: http://www.rcuniverse.com/forum/m_7948096/tm.htm
Regards, Jan.
CA
ORIGINAL: pompebled
I have four of these 100A ESC, made them watercooled, they run fine, but need some work, to correct the sloppy soldering of the Fets.
Regards, Jan.
Regards, Jan.
I use one of these esc's running a 8S in 5 of my smaller hulls.
I have used it straight out of the packet as such and have no usb or field programmer.
The only thing I did was to disable the reverse function......not much use in a rigger anyway.
I use it with a Hitec 40FM pistol radio and have had no problems with it.
It gets warm in my hydro but that thing is an amp pig anyway.
The X-power gets my nod of approval.
Thanks to you all for the information, I did not have any hits on friday so I didn't bother looking at this thread over the weekend.
Bruce
Bruce
ORIGINAL: ibyte69
Very impressive work pompebled. takes alot of know how to do what you did its not as easy as people think. soldering anywhere on or near the esc is a hairy operation. great pics of your work
The 100A ESC's are build quite robustly and will take a certain amount of 'abuse'.
If you work carefully, it's no big deal (it's only hairy on the first one).
Regards, Jan.
ORIGINAL: pompebled
That is good news for me, as you know I can be very hard on gear. Nearly all of my hulls smell of majic genie smoke !
So far I have had this speedy warm, I guess 40-50 degC.
It has survived so far and if it makes it untill Christmas I will get another one so that there are fewer component changes at the pond.
To give you an idea on how hard I can be on gear.
A senior fire officer once said. "To understand how hard a Firefighter is on gear think of this. Put him in a concrete prison cell with two cannon balls. Half an hour later come back and he will have lost one an broken the other"
The X-power rocks !!.....for now
PA
I just purchased the ESC above with USB programmer. I have a PC but I do NOT have a laptop to take along. How should I program for the cell number if I want to try using all 2, 3 and 4 cells Lipo at the lake?
If I set for 4, it will work for 3 but not 2 cells. But if I set for 3 it will also work with 2 but what will happen if I use 4 cells but set for only 3 cells?
Simon.O. said he used it straight out of the packet with 8S. The default setting is for only 2S, so I guess I can set it to 2 cell and can use it up to 5S??
Tanasit
Tanasit
MA
ORIGINAL: Simon.O.
Jan.
A senior fire officer once said. ''To understand how hard a Firefighter is on gear think of this. Put him in a concrete prison cell with two cannon balls. Half an hour later come back and he will have lost one an broken the other''
ORIGINAL: pompebled
Steven
OSE
I ran across this Feigao performance chart..........I refer to it often, you can use it i case you are considering a better motor also. You could run the 10L with a max amp draw of 61 and a kv of 2602. That would give you speed AND torque with the 60mm can. I use the 60mm motors in several of my boats.
MA
Just to clarify a bit on that chart. Its amps at max efficiency. So if you gear or prop a boat to run at those amps, it will have its max efficiency. But you can easily draw twice as many amps by over propping.
Steven
OffshoreElectrics
Steven
OffshoreElectrics
