Go Back  RCU Forums > RC Boats > Speed - Electric
 flex shaft >
flex shaft
Speed - Electric For all your electric boating needs.
flex shaft
Old 01-06-2009 | 04:11 PM
Default flex shaft
This is my first boat with a nylon liner inside the proptube , Do you still have to grease the flexshaft every couple of runs like i do with my gas boat ?.....
phil.
Old 01-06-2009 | 08:39 PM
SV27dayton's Avatar
Default RE: flex shaft
Well I don't think it's certain as I don't think we know what boat you are talking about but generally yes you should lube it ever trip to the water.
Old 01-07-2009 | 04:15 AM
I am sorry i should have said its a prince 25" 1107 model with a 4mm shaft .
thanks phil.
Old 01-07-2009 | 04:26 AM
Hey Phill,
Yes lube the flex shaft as if you dont you can melt the liner.....
Many people do not use a liner anymore but i have never had a problem with running them.
I just lube every run or sometimes every second run.
