Go Back  RCU Forums > RC Boats > Speed - Electric
 Flex Collet >
Flex Collet
Speed - Electric For all your electric boating needs.
Flex Collet
Old 01-29-2009 | 12:26 PM
Default Flex Collet
Where is the best place to buy flex collets? Also where has everyone found to be the best place on-line to buy boat parts?
Old 01-29-2009 | 12:31 PM
Default RE: Flex Collet
http://www.offshoreelectrics.com/index.php
HTH
Steve
Old 01-29-2009 | 11:34 PM
HOTWATER's Avatar
Yes...Offshoreelectrics...Steven V. ....The best service and shipping!!!
Old 01-31-2009 | 09:17 AM
They said they don't have any 4mm flex colletts. Any other suggestions?
Old 01-31-2009 | 11:44 PM
HOTWATER's Avatar
I found another place...Allfield-RC.com. $7.69...
-Kent
Old 02-02-2009 | 06:47 PM
Ok, here is what I have found out so far and need some help. I used a caliper and found that my collet is in fact 4mm. My motor shaft is, however, 3mm. The collet is very loose on the shaft. My motor shaft already has a flat spot on it for the allen screw. Is there anything I can do to correct this re did I get a bad motor?
Old 02-02-2009 | 07:19 PM
PER PM you need a collet.
The one thats in your boat isnt the right one.
Old 02-02-2009 | 08:00 PM
http://www.offshoreelectrics.com/products.php?cat=68
1/8" to .150"
And if your new to the hobby and dont already have it:
http://www.offshoreelectrics.com/pro...rod=hatch-tape
http://www.offshoreelectrics.com/pro...od=dh-aqub9500
And you will need appropriate allen wrenches
Old 02-02-2009 | 08:27 PM
Thank you Basstronics! Now I have to figure out the one I need. [X(] It was good to know the other stuff also.
