Speed - Electric For all your electric boating needs.
paint
Old 01-31-2009 | 06:10 PM
Default paint
when you paint your boat,what type of clearcoat do you use? i painted with parma fasblack,faswhite and faswhite.
Old 01-31-2009 | 06:13 PM
Dreamin Hemi's Avatar
Default RE: paint
Depends where you live. Here in states, urethane clear coat is typically used most often
Old 01-31-2009 | 06:15 PM
Default RE: paint
well i live in Canada,will only be in freshwater lakes, maby a chlorine pool. do you have any links to a good recomendation?
Old 01-31-2009 | 06:57 PM
pzrwest's Avatar
Default RE: paint
James you can get spray gloss urethane at Canadian Tire.
Old 01-31-2009 | 07:02 PM
Default RE: paint
thanks alot.
Old 01-31-2009 | 09:56 PM
detox's Avatar
Default RE: paint
Nothing fancy or expensive...just Krylon primer, paint, and clear.
Old 01-31-2009 | 10:20 PM
Default RE: paint
ive already sanded,painted the base coat(black) and am now doing my flame stencils.the flames are airbrushed so cant use regular spraypaint.
Old 01-31-2009 | 10:57 PM
pzrwest's Avatar
Default RE: paint
Well you can clear coat when finished with the spray urethane or you can buy tins of clear gloss urethane and thin and spray with your airbrush. Just will take several coats to get a high gloss finish. Why do you say you can't use a spray bomb of clear gloss urethane?
Old 02-01-2009 | 12:01 PM
Default RE: paint
ya, i think thats what i'll do,thanks.
Old 02-04-2009 | 05:59 PM
Default RE: paint
are you talking abouth the urathane used on wood applications?all the urathanes me and the helper person could find
were supposed to be for wood
