I need help matching BL motor to my 80A esc
MI
Hi,
I have a 80a BL esc that I'll drive with two 3s 2100mah 30c packs wired together into a 3s 4200mah pack. Or I'll run two 2s 3800 28c race packs in parallel as a 4s 3800mah pack. I plan on putting this into the smallest hull I can fit everything into. What size motor should I use?
thanks
mike
thanks
mike
RE: I need help matching BL motor to my 80A esc
This will help you work out a few possible combinations.
[link]http://forums.offshoreelectrics.com/showthread.php?t=4159[/link]
Just a small point though. I think you mean that you will run two 2s 3800 28c packs in 'series' (not parallel as written) to give you 4s.
All the best.
Paul.
All the best.
Paul.
