Go Back  RCU Forums > RC Boats > Speed - Electric
 Arpro P1 Brushless, ESC setup help? >
Speed - Electric For all your electric boating needs.
Old 03-18-2009 | 01:17 PM
Default Arpro P1 Brushless, ESC setup help?
Hi everyone, I just got this boat in and charged the battery up and plugged the battery to the esc after turning on the transmitter then plugging the battery up. It beeps twice....then it beeps once...then twice......then three.....then four....then five....and so on until 15 beeps, after that it repeats itself.
What am I doing wrong? Can anyone help me out please? Any help would be great!
Sorry for being a newb to ESC's
Thanks, J
Old 03-19-2009 | 07:42 AM
Apache-Sven's Avatar
Default RE: Arpro P1 Brushless, ESC setup help?
I'm not sure how to help you as I do not know which speed controller you are using, but it sounds like its asking for transmitter input to set it up. Check your manual to see if they tell you how to set-up the esc, if at all. If it doesn't let me know which esc it is and I can help you from there. If it's an all in one unit (esc/rx combo) then it should be a plug and play unit and may require the help of the makers of the boat.
Old 03-19-2009 | 02:34 PM
Hi thanks, I will go home after work and let you know asap! Thanks man :-)
