cooling with fuel pump?
My Feedback: (10)
hi
i got it now i think i am going to use this and i going to wire it with a 6 volt resisteror from the esc which is feed 12 volts,http://www3.towerhobbies.com/cgi-bi...?&I=LXDES1&P=SM this is the esc http://www.modelcontrol.com/sc480.htm so that the pump works when the motors work to pump water though the cooling tubes , will this setup hurt the esc or pump,i try this one but it wasnt putting out enough i think the wire that i was using which is the same gage as the Sullivan wasnt enough for this pump ,i am not going to be going fast enough to push water though the tubes this boat is a large cabin crusier 48" and is going to have moving dolls on the rear deck and a ipod music with speakers ,check it out on youtube ptboat84 all one word its my web page for all my rc stuff thanks rye
My Feedback: (10)
RE: cooling with fuel pump?
sorry heres the web page for the pumps
http://www3.towerhobbies.com/cgi-bin...?&I=LXDES1&P=7
http://www3.towerhobbies.com/cgi-bin...&I=LXDJR7&P=ML
My Feedback: (10)
hi
i try that it not as good i like water coolers it hard to get them right on my 5" pt boat it took three trys to get the sweet spot and the esc cooler is weak but it all works,with the cost of esc i have four of them they are great i want to try to keep them as long as i can ,and this guy i get them from is hard to get but a bear to get them 4-5 months replairs, forever i know i should look else where but there great and they are water cooled
so i am going to try this frist thanks rye
Hi Rye,
Keep in mind most fuel pumps are not designed for continuous operation, running it on a lower Voltage will surely help keeping the (pump)motor temperature down, but keep an eye on it anyway.
Even if you're not going fast, with intakes behind the props and a suction outlet, you should have flow through the cooling system, without a pump, even when just crawling along...
Regards, Jan.
Regards, Jan.
My Feedback: (10)
hi jan
well i hook it up to the esc motor side and it only works as you pull the trigger no resisteror and its quiet i will be testing it some time in april for now i test it in the tub tight fit but it pumps go i will be going slow past all the peoples who live on the pond and music and dancing doll with all the lights would be missed if i had to move faster then a crawl here the finish model thanks for your help, rye
http://www.youtube.com/watch?v=VJ6bLRgcXCs
