ul1 motor upgrade
FL
ul1 motor upgrade
What is a good motor upgrade, im not looking to buy an ammo of feigao. Is this any good?
http://www.unitedhobbies.com/UNITEDH...200kv_Inrunner
Also: What is a good mm prop to put on from graupner? Thanks!
ON, CANADA
RE: ul1 motor upgrade
Well, the stock prop for the Super Vee and the UL-1 is a plastic x440 3blade. So, with graupner just go with a 3 blade 40mm or start with 40mm 2blade props up to 45mm. Just watch the temps when running 45mm or bigger prop.
Are you meaning the 4mm threaded props or the carbon filled glass props that use a drive dog??? I refer to the latter.
My Feedback: (20)
ORIGINAL: verado
also 450watts vs well over 750watts stock, some are getting 1300watts peak out of the stock UL-1 motor!
This motor could help go in the direction you want..
http://www.hobbycity.com/hobbycity/s...hless_Inrunner
