Speed - Electric For all your electric boating needs.
COG?
Old 07-23-2009 | 02:30 PM
Default COG?
where should the center of gravity be around on a deep V mono</p>
Old 07-23-2009 | 03:55 PM
Default RE: COG?
Somewhere between 29% and 35% of total length of hull,measured from the transom.
Brod..
Old 07-24-2009 | 07:16 AM
Default RE: COG?
thx brod.. u have been a big help and have given me alot of usefull info
Old 07-24-2009 | 10:52 PM
Moppie's Avatar
Default RE: COG?
If your asking about CG you should also take care of your strut angle.. This plays a big parts as well. And if you have trims than it gets even more sensative.
For a deep mono you should start out with the drive strut being parallel to the hull.
Then I would suggest you start to move the CG around to create a stable boat .
Start at 30% of the distance from the transom.
Moppie.
Old 07-25-2009 | 01:05 AM
My Feedback: (20)
Default RE: COG?
30-33% is a great place to run COG on a mono..
less than 30 will be lose but fast and fun, more than 33% and things get wet and slower..
Old 07-25-2009 | 10:19 AM
Frankinsten's Avatar
Default RE: COG?
ORIGINAL: srt10
Like Srt10 Said, Depending on what you want the boat to perform like is where you want the COG to be. Our team has a small electric boat with the COG at around 25% and it is very good fun to use. Always keeps you alert.
Tom
