Go Back  RCU Forums > RC Boats > Speed - Electric
 Brushless motors >
Brushless motors
Speed - Electric For all your electric boating needs.
Brushless motors
Old 02-17-2010 | 06:11 PM
Default Brushless motors
I have always run brushed motors graupner 700 neo, with jetti 600navy. but i now have a bigger boat, an the motor is not right so my question is what do i need to no before i get a brusless motor?
new esc?
new battery pack i run nicads?
diffrent shafts an props?
simple things which may or will make a diffrence thanks chris
Old 02-17-2010 | 09:48 PM
Default RE: Brushless motors
a brushless motor will probably laugh at your nicads , they are 2 or 3 metal advancements behind. yes you need a new esc to go brushless, should be able to keep the shafts, keeping the prop depends on the new motor
Old 02-17-2010 | 10:37 PM
You should start by selling me your 700 and esc for a good price
Old 02-17-2010 | 10:40 PM
bump
Old 02-17-2010 | 11:45 PM
FAZDA's Avatar
In my boat club we run spec classes in which we run stock Aquacraft SV27 and UL-1 motors or the stock Proboat black jack 26 motors which are cheap for their level of performance. We also run unlimited classes which can use any motor, a high performance low price one are the Feigao motors which come in all sorts of sizes. You will need a new esc specifically for brushless and currently our club runs lipo battery packs. You can get everything you need and learn more at www.offshoreelectrics.com.
Old 02-18-2010 | 12:19 AM
My Feedback: (20)
nicads will not keep up with the amp demands of brushless motors
go lipo, they are getting cheap
Old 02-18-2010 | 02:01 AM
ok so a new esc an batts then, dont fancy lipos. So the nicads will work but drain very quick so its goin to be very expensive to swap over chris
Old 02-18-2010 | 02:07 AM
My Feedback: (20)
ORIGINAL: chrisholleyuk
nicads will not work in my opinion because they cannot keep up with amp draw of a brushless motor, this will cause the cells to get very hot and damage them.
also the small capacity of them will not yield very good run times at all
lipo batteries are very easy to charge and maintain
Old 02-18-2010 | 02:55 AM
what size is the boat...... this determines the size of motor, batt and esc
is it for fun or competitions
i see your determined to run nicads and as people have pointed out, lipos are much better but if you dont want to go with lipos then theres no point going brushless
Old 02-18-2010 | 03:47 AM
Cornelp's Avatar
Guys are right... first change will be to go Lipo. I can confirm that even a brushed system will go though a noticeable change if you go Lipo. A bit like a new boat, as far as response. Check some of the prices here:
http://www.hobbyking.com/hobbycity/s..._40C_Lipo_Pack
This will give you loads more power and the price is not that different from a good NiMh pack. BTW, if you login, the prices go down...
My opinion: go Lipo first, get the taste of it, than slowly upgrade. If you run scale boats, there is no real point, as the speed of a brushed system is a lot more scale...
Old 02-18-2010 | 11:36 AM
My Feedback: (20)
I agree with Cornelp.
If you were to just change to lipo even with your brushed motors you would see a big jump in power!
and not much money spent doing so
Old 02-18-2010 | 12:10 PM
maybe lipos must be an option, what happens if the inside gets wet? was told to keep lipos dry??? iam running 3 boats graupner b24- gancia dei gancia an my new one which blow the brushes 32inc twister mono. but will really look into brushless-brushless esc-lipos
Old 02-18-2010 | 12:21 PM
My Feedback: (20)
just like most electrics that get wet, let them dry out completely before turning them back on..
lipos will be just fine
