Power Supply for HYPERION EOS720I NET 3
I just aquired this lovely charger and it came with NO POWER SUPPLY. I read the manually it states i can use any power supplies with the the output range 11-28v but doesn't say anythign about the amp i guess it doesn't matter as long as it isnt too low (less than 2A?) Instead of buying a power supply, i can i just hook it into my 12v car/marine battery instead? I have a 115AH marine battery. I also have a laptop power supply 16v 4A.
RE: Power Supply for HYPERION EOS720I NET 3
whats the input range, this is the important thing, its like using a 12v charger for a 24v battery or as here in england we have 220v-240v mains
Ohh..nevermind, i just read in the mannual i can use a FULLY CHARGED car/marine battery, GREAT! This charger has voltage and amperage control 8))
sounds like a multy charger to me, where (as you said) can select voltage and amperage, test on an old battery before you try it on your better batterys
nick
nick
