Go Back  RCU Forums > RC Boats > Speed - Electric
 supervee 27 problem >
supervee 27 problem
Speed - Electric For all your electric boating needs.
supervee 27 problem
Old 03-10-2010 | 06:42 PM
Default supervee 27 problem
The housing (blue) on the brushless motor is pulling away from the magnet when the boat is ran. This causes the housing to spin and disconnect the plugs. I am tired of swimming. How can this be remedied?
Old 03-10-2010 | 08:04 PM
dicko's Avatar
Default RE: supervee 27 problem
You need to put a thrust washer between the collet and the motor, this puts the load onto the front of the motor can & takes it off the back of the can.
Old 03-10-2010 | 09:52 PM
SV27dayton's Avatar
That's cheaper than replacing the motor.
Old 03-10-2010 | 10:45 PM
would the hobby shop where I bought the sv27 have a thrust washer to fit?
Old 03-11-2010 | 01:00 AM
dicko's Avatar
Probably not, offshore electric would be your best bet.
Old 03-11-2010 | 02:15 AM
i just added another bearing on the motor shaft but it was large enough to fit in the mount hole where the shaft goes through</p>
Old 03-11-2010 | 02:28 AM
My Feedback: (20)
this is what ya need
http://www.offshoreelectrics.com/pro...?prod=dh-53136
Old 03-11-2010 | 02:44 AM
the only difference i see is that the side of the bearing is open so its all half encased
Old 03-11-2010 | 03:48 AM
dicko's Avatar
A thrust bearing is meant to be run in compression along the shaft it is mounted on, a normal bearing will run in compression at 90 degrees to the shaft it is mounted on.
Old 03-11-2010 | 11:59 AM
My Feedback: (20)
ORIGINAL: dicko
+ 1
a normal bearing will not work well for this aplication
Old 03-11-2010 | 12:01 PM
its ok, i have ordered some, should be here tomorow with any luck, it goes between the can front a coupler ??
Old 03-11-2010 | 12:03 PM
My Feedback: (20)
the thrust bearing goes between the motor and the coupler
Old 03-11-2010 | 11:36 PM
sundogz's Avatar
Yep, the motor cap bearings are good for side to side loading, but poor for transmitting forward thrust. For that, you need a thrust bearing. A bushing between the drive dog and the strut does the same thing, albeit not as efficiently.
