Apparition-II Twin Hull w/ Twin motor (800mm)
Hi i ordered this boat
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=11739&Product_Name=Apparition-II_Offshore_Brushless_RC_Twin_Hull_w/_Twin_motor_(800mm)&aff=27556
all so those lipo pack's
http://www.hobbyking.com/hobbycity/s...7556&aff=27556
please tell me it will work!!!
My Feedback: (20)
RE: Apparition-II Twin Hull w/ Twin motor (800mm)
Looks like a great package!
those batteries will rock, as long as the motors can keep up
please post a video, I found a vender and I might try one of them
I do know that hull is awesome, many have done some amzing builds on the hull with some big power
I think there is a video on youtube with this HOR hull with 540 twins doing 70mph on 4s I think
KOS looks better IMO, but this is still a great looking boat. And it's the price that's won me over. I'm keen to see some video of this thing in stock form.
My Feedback: (20)
ORIGINAL: 13BT
I need to find the video of a HOR cat doing 70mph (this hull)
Yes, I was comparing appearances only. And I failed to notice this is not rtr so I'd have to consider the costs of the extras. I wish I wasnt so poor
The video above is with 2s battery's i will put a vid with 3S i have allso 4s 3600 25C can i use them to or they are to big?
ORIGINAL: srt10
please post a video, I found a wonder and I might try one of them
I do know that hull is awesome, many have done some amazing builds on the hull with some big power
i intend to play around a little bit disassemble the hardware and do proper light hull from carbon fiber and epoxy resin i hope to remove half the original weight
LA
Yeah this boat looks sweet!
I wonder what kind of cut off options the ESC has for the lipo batteries? I have found that with these newer high C batteries I need to set cutoff's more around 3.3-3.5 volts or else the boat will drain the pack almost empty......
Can't wait to see one of these on 3s...
Will the 70A ESC will hold the 3s 5000ma 40c ?
can i test the setup with this ?
http://www.hobbyking.com/hobbyking/s...yzer&aff=27556
My Feedback: (20)
ORIGINAL: tornad0
You can blow the esc with 20c 5000mah packs
This boat will do just fine with 20c/30c 5000mah packs
ORIGINAL: FE_Chris
i don't like the cutoff i have to some how brig the boat to shore and some times i go to the lake with 1 boat and don't have the privilege of rescuing
ORIGINAL: srt10
Its really not the esc to watch for but the motor and how its proped...
ORIGINAL: tornad0
My Feedback: (20)
ORIGINAL: tornad0
What about 40C ??
ORIGINAL: srt10
ORIGINAL: tornad0
40c will work the same as 60c...
Not worth the extra money for these 380s imo
My Feedback: (20)
ORIGINAL: boatfisher25
i got a 4s 3000 mah 20c battery for my genisis will that work?
finely i received my boat today
i ordered the battery's in a different shipping
can i run this boat with two 4s3600ma25c?
soon i will post the pic's
My Feedback: (20)
ORIGINAL: tornad0
running 4s is this boat on those high kv motors is not a good thing.. [:-]
these motors are better for 3s packs
hi i started assembling the boat and i want to do several changes
the boat is twin motor and there is no contra rotating props
two of them spinning in the same direction
i am interested to fix that issue
now the prop is 2 blade unknown maker from cooper with 435 stamp on it any ideas ?
how to choose 3 bladed prop fore the stock setup and if there is any need fore me as a beginner to do that ?
i have to change one of the flex shafts
about the battery's i see that using 4s on high kv motors now what is high kv is 2800 is high
can i use 4s but not squeeze all the juce from the battery's run on half throttle ?
