What use is a 60 amp
From: BROKEN HILLOutback New South Wales , AUSTRALIA
Hi Guy's ,
My Brother has a BJ26 that he is putting together as project with his son , amongst his gear he has a cheap watercooled 60 amp ESC & a , could you recommend him on a suitable set up that will not cause excessive heat with his ESC , such as 3s or 4s batts ??
Brad
if it is a brushless ESC, you could look at the KD36-60-11L and run it on a 4s pack.<div>
</div><div>Truly, we need more information. Can the ESC even handle 4s?</div><div>
</div><div>The more info the better, hull type size, any motor or prop combo, both voltage and amp rating for esc (brushed or brushless).</div>
Hi Nobdyfamous ,
Sorry for not being more detailed , my brother has the following peices so far ,
1) BJ26
2) 60 Amp ESC
3) 36-60-09 BL Motor
He has no Prop at the moment so i guess that should be on the smaller diameter size to cause less amp draw wanted guage what the ESC could handle , without overheating . Is there any of his parts that you would replace - maybe buy a hgher rated amperage ESC ??
Brad
