Go Back  RCU Forums > RC Boats > Speed - Electric
 Batteries or....? >
Batteries or....?
Speed - Electric For all your electric boating needs.
Batteries or....?
Old 07-27-2010 | 04:39 PM
Default Batteries or....?
Hi All
Went to charge my batteries. Had not used them in months. They charged very quickly (or so I thought). When I got to the water. It ran for 2 secs. Lucklily it didn't get too far away! But why did this happen? Did the batteries go bad? Ther are 3300 MaH Nimhs
Thanks for any input
Old 07-27-2010 | 08:43 PM
My Feedback: (325)
Default RE: Batteries or....?
It sounds like they really didn't charge.
Old 07-28-2010 | 04:47 AM
If you use an auto peak detect charger, old batteries that have sat for a long period of time, especially NiMh will self discharge.  They get down to almost 0%.  The charger is then fooled into thinking it is like a 4 cell pack rather then a 6 or more.  The batts will act like they have a full charge but they do not.<div>
</div><div>Cycle the batteries a few times and they will regain some capacity.  You may need to put them on a trickle charge for an hour or so to get em started.  They most likely will not hold 3300mAh anymore.  Sound like a good time to upgrade to Lipo from HK!</div>
Old 07-30-2010 | 06:41 PM
My Feedback: (20)
ORIGINAL: Diesel Power
Hi All
run them through a few cycles
they should come back to life with no issues
Old 07-30-2010 | 07:56 PM
SV27dayton's Avatar
I had some IB racing cells that would dump like that in a few weeks. The voltage would come up very rapidly and the charger would stop. You may have to hit start a few times before it starts to put some real juice in them.
Old 07-31-2010 | 10:29 AM
Hey Guys
Thanks for the input. I have a Venom Pro charger and not quite sure to to do a trickle charge or...? Would I lower the chatge amps?
Thanks again! [8D]
Old 07-31-2010 | 10:43 AM
My Feedback: (20)
Yes, I would set the charger at .2 - .4 amps
