RCU Forums
-   Speed - Electric (https://www.rcuniverse.com/forum/speed-electric-109/)
-   -   programing tenshock esc (https://www.rcuniverse.com/forum/speed-electric-109/10257902-programing-tenshock-esc.html)
dudley171 01-12-2011 09:03 AM
how do i use the program card for a mini cat or mini Y
wilsta67 01-12-2011 10:55 AM
RE: programing tenshock esc
read the instructions i can give you the switch settings but will need to no what battery u are using how many cells it should be a 3 cell.?
you will also have to set up the throttle on your radio but you cant do this until the card is set up.
dudley171 01-12-2011 11:58 AM
I bought the Carbon Fiber mini cat and the mini Y from gravity hobby but i got no paper work  at all on these boats,NOTHING
Diesel6401 01-12-2011 03:23 PM
This may help http://minicatracingusa.com/images/i...scinstruct.pdf</p>
wilsta67 01-12-2011 09:48 PM
ORIGINAL: dudley171
i have the same boat the mini carbon fibre.
this is the battery you will need. in the link.
you will also need a charger.
http://www.hobbyking.com/hobbyking/s...dProduct=14857
http://www.hobbyking.com/hobbyking/s...idProduct=8932
you will also need these to solder to the esc for the battery to plug into
http://www.hobbyking.com/hobbyking/s...idProduct=9572
the settings on the card are as follow
1on
2off
3on
4off
5on
6on
7off
8on
9on
10off
11off
12on
img819.imageshack.us/f/img002wp.jpg/
img190.imageshack.us/f/49671174.jpg/
img521.imageshack.us/f/64894623.jpg/
both of the boats should be the same set up.
hope this helps!
dudley171 01-13-2011 08:39 AM
Thanks for the help.Why don't these boat sellers give you the info on how to operate &amp; set up these boats
wilsta67 01-13-2011 10:38 AM
ORIGINAL: dudley171
it took me 5 days of ripping my hair out to work out that stuppid programming card. i was ready to chuck the whole kit n cuboodle in the bin.
wilsta67 01-15-2011 01:32 PM
here is a video i shot yesterday of my mini cat.
[youtube]http://www.youtube.com/watch?v=BspW5l8vtQM[/youtube]
dudley171 01-16-2011 11:13 AM
your boat is realty fast, are you using a 2200 20c 3cell battery?What about the prop?
dudley171 01-16-2011 11:22 AM
I ahven't got a chance to set mine up yet, I am starting on the mini Y first.Its tite to fit it all in there
wilsta67 01-25-2011 12:27 PM
ORIGINAL: dudley171
did you get it sorted?
dudley171 01-31-2011 06:48 AM
Yes thanks for your help
