What to do with this ESC?
I accidentally bought thishttp://cgi.ebay.ca/ws/eBayISAPI.dll?ViewItem&item=300562094339&s sPageName=ADME:L:OC:CA:1123
It's a DuraTrax IntelliSpeed 12T. I hope it works. Do you think it will work on my stock Villain IV? It is running the stock duel brushed 540's (6 cell/2s) Or should I just put it in my stock Stampede?<br type="_moz" /> |
RE: What to do with this ESC?
http://www3.towerhobbies.com/cgi-bin...P?I=LXAXT9&P=8
That's rated quite high. If specs are correct it should work. Check temps constantly for the first bit. Only 2s LiPo though. Ryan |
yeah, 232 amps continuos is really good. I wonder if I can get away with some half @$$ cooling for it though.<div>
</div><div>I had a proboat marine ESC and added my own water cooling (built a water jacket on 1 side with silicon & plastic) but it still smoked on me. Didn't over heat, just went poof! I may try something similar with this one.</div> |
Smoke suggests a component has overheated. :)
ESC's that are filled with hard epoxy type case don't benefit from water cooling all that well. An ESC with visible heat sinks will conduct heat at a level you can measure. This may be the difference in your previous experience? Ryan |
ORIGINAL: ryan_t888 Smoke suggests a component has overheated. :) |
| All times are GMT -8. The time now is 04:24 AM. |
