Brushless recomendations
Boat is a scale PT in 1/35 (not one of the plastics).
Props are 3/4" diam brass w/ 1" pitch.. Want to go Brushless for no other reason than I can. What motor would you guys recommend to drive ONE prop at approx 5000 rpm in the water?. |
What voltage will you use? What ESC do you have? Water or air cooled? Budget? No one can give a meaningful answer without this information.
Originally Posted by Got RPM
(Post 12648304)
. Only restriction for the battery is I want to go with a LiFe. Weight is one consideration to this. Since there will be 3 of them I was thinking something along the lines of the Cobra C-2204/58. Just to provide an example. Budget is pretty open but I don't want to get crazy. This is a fun project and will probably be more display than actual running. |
| All times are GMT -8. The time now is 07:14 PM. |
